Question about Ashley Furniture ASHLEY B527-57/64/98 Queen sleigh storage bed
Lost the screws in the move to put bed together brand ashley B5227
What kind of screws to use to replace lost ones
2 Suggested Answers
  • 1443 Answers
SOURCE: I recently moved and lost my screws to my shay poster bed. Can i order replacement screws?
go to a furniture store that handles the Ashley product and they will have or can get them, call the furniture stores and ask them
Posted on Dec 30, 2015
I need help disassembling an Ashley Zayley full size bed. There are 4 sets of screws that are holding the bed together but none of them will unscrew.
Screws in beds are designed to be quite tight, so that there's no movement, which would be quite aggravating to the person lying on it. Likely the constant movement has seated the screws even more firmly. I can only suggest better tools, or drilling them out.
Jun 16, 2017 | Baby Gear
I lost the screws to put the bed back together again.
go to a hardware and buy new ones . we have never seen your bed to know what is missing .
Feb 17, 2016 | Baby Gear
Dec 30, 2015 | Ashley Furniture Shay Poster Bed
Can I order replacement hardware to put the bed together? Ours was lost in a move.
It's hard to tell from your photograph, but I think that's a Delta Children's bed. If so, you can get extra or replacement hardware by calling them at: 1-800-377-3777 M-F 8:30am-6:00pm Eastern
Nov 18, 2015 | Disney Pixar Cars Toddler Bed
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
Need screws to put baby bed back together (lost previous screws)
Simplicity for Children Ellis 4-in-1 Convertible Baby Crib
i lost all the screws and directions i need a new set does anyone know were i can any
Mar 24, 2008 | Evenflo Jenny Lind Crib
Ashley Furniture ASHLEY B527-57/64/98 Queen sleigh storage bed Logo
43 people viewed this question
Top Ashley Furniture Furniture Experts
Lawrence Oravetz
Danny Kuhlmann
Are you an Ashley Furniture Furniture Expert? Answer questions, earn points and help others
