Question about Furniture
The wiring connections are different on thr new Sentri 3 controller and I'm not sure which wires go where?
Part Number 7cv91sa
  • 4234 Answers
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
praky16
  • 744 Answers
SOURCE: xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Posted on Feb 10, 2009
psycondric
  • 42 Answers
SOURCE: my new wireless mic wont connect to my wired controller
Hi, i think ur number 1 is configured for wireless functionality. So it will not work when the wire is connected. Try configuring the mic to work when the wire is connected as well. There should be a setting for it in the mic software. It should work after that
Posted on Jul 08, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Sep 15, 2009
RyanFanMan
  • 342 Answers
SOURCE: Need new fan speed switch. Also need wiring
go search for a wiring diagram then look for a switch for your fan
Posted on Jan 01, 2011
I am trying to determine which wires correspond to the correct plugs as they are numbered slightly different. Is their a diagrsm i can follow for this specific switch model # 318369616?
The important thing here is to make SURE the wires from one switch are connected to the same terminals on the new switch...the physical locations might be different but as long as the wires that are at L1, L2, H1, H2, 2p are connected to the SAME terminals on the new switch, you should be good.(use this as JUST AN EXAMPLE BECAUSE I DON'T KNOW THE MODEL RANGE YOU HAVE!)
  • l1 connects to 3-l1
  • l2 connects to 5-l2
  • h1 connects to 1-h1
  • h2 connects to 4-h2
  • p connects to 2-p
  • I need the part number of the old switch *and* the new one to be able to better visualize the connections. Thanks.
Aug 25, 2015 | Kitchen Ranges
Fix 3way switch
Feb 2013
1) Copy following link for 3-way switch wiring
http://waterheatertimer.org/How-to-wire-switches.html#3-way
http://waterheatertimer.org/images/Switch-quick-connect-400.jpg
2) Usually a bad switch is replaced.
Buy another 3-way switch.
New switch will have 3 screws (plus green ground screw which is not discussed further).
On new switch, 1 screw will be different color from other two screws.
Same thing with old switch: 1 screw will be different color.
Take wire on different color screw and connect to different color screw on new switch.
Other two wires can connect to either screw.
Feb 02, 2013 | Electrical Supplies
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
I found out the intermatic did not work as usual, just change new battery, i try to program the schedule, but it did not work.
If you have a battery operated timer, it is probably the Intermatic ST01C or EJ500.
http://waterheatertimer.org/Programmable.html
The link above will help you identify your timer.
As a general rule, if a new battery does not revive the Intermatic timer, then timer needs to be replaced. Make sure you have electricity. And be sure to mark your wires before removing timer. Mark the black wire that connected to timer-black wire. It's the hot wire from breaker box.
You can replace with same model and brand so your wiring is EZ.
The ST01C and EJ500 are 7-day timers with up to 40 programs per week. They each connect with 2 wires. Black and Blue with red wire capped off. Just mark your wires before you disconnect old timer. And then reconnect new timer wires just as old timer was connected. The red wire is capped off.
The Aube T1032 is also a 7-day timer with 7 programs per week. This timer connects a bit differently. It connects with 3 wires. You put the black where old timer-black wire connected. And then you connect the red and blue together and connect them where the old timer-blue wire connected.
Other timers require wiring that is bit different, but the page link above shows the wiring ... and you can re-post another question any time >>> or respond to this answer.
Keep us posted.
Oct 22, 2010 | Hardware & Accessories
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
I have a Leviton 5634 two rocker switch that I'm using to replace an old double switch that controls two lights. There are 1 black, 1 red, and 1 white wire in the light switch box. The white wire is...
Review old switches:
Two old switches > each has 2 wires
Old switch 1 > Red and White
Old switch 2 > Black and White
The same white wire connects to both switches, so effectively they count as 1 wire
This means you have 3 wires ... 1 White, 1 Red, 1 Black
Each switch controls a separate load (light, fan, motor)
New Leviton double-rocker switch:
-Leviton has 2 Brass-colored screws on one side, and these screws are connected together by a brass plate >> your Hot wire will connect to brass screw
-Leviton has 2 Silver-colored screws on other side, and neither of these screws are connected in any way >> the wires going to each load will connect on a different screw on this side of switch.
Hot wire: Each box in your house has exactly 1 hot wire that is connected back to breaker box. This is true for all boxes (excluding boxes that have a 3-way & 4-way switches).
We need to identify Hot wire.
-By code the Hot wire is black for identification purposes ... but your box sounds like maybe the Hot wire is White.
-If your Hot wire is white, that is NOT an immediate safety issue ... it will not cause a fire or malfunction ... it is a code violation ... because code requires things be uniform so next electrician knows what previous guy did. So some day, electrician working outside grabs wrong color wire, and wow. I say this so you know.
Moving on.
Identify Hot wire:
-Pull 3 wires up so they can be tested
-Turn on power
-Use ordinary tester, or old lamp with plug cut off and wires stripped back
-Tape tester lead to sticks so hands are away from voltage
-Power is on. Don't stand in water or touch metal pipes, and you're fine.
-You have 3 wires in box + ground wire
-Test all 3 wires to bare ground wire >> when tester lights up, that is Hot wire ... testing is complete
Connect wires to Leviton double-rocker:
-Power is OFF.
-You have 3 wires - 1 White, 1 Black, 1 Red >> one is Hot wire, the other two wires go to load
-Hot wire connects to Brass-colored screws on new Leviton.
-Brass colored screws are connected together by a brass plate so the Hot does not need to connect to both brass screws.
-The other two wires connect to Silver screws on other side of new Leviton switch
-One wire goes to each silver screw
-Connect bare ground wire to green screw.
-Push wires back into box. Use eraser end of pencil if needed.
-Make sure ground wire is back and away from screws on switch
-That's it.
Sep 30, 2010 | Leviton Electrical Supplies
I need to replace the control panel on my dryer how hard is it to do the myself
The hardest part is being sure you get the exact same control panel. Make sure you know the brand, model, and serial number, and any other numbers will help when ordering it. I would Google the brand name and try to find their website or a telephone number. It also could be bought from an appliance repair store on-line or in person. When you get it, look at it and make sure it is the same BEFORE you unwire the old one. I bought a booklet of wire numbers from Home Depot and labeled every wire, and every terminal it came from. If your control panel is hardwired, meaning no terminals to unhook the wire, simply put a number a few inches back from each control wire, and one close to the OLD controller before you cut the wires and remove it. Make sure you leave enough wirewhen you cut them to reach the new controller. It's not that hard, just don't get in a rush and cut wires before they are marked, because you are going to use the old controller with the wire attached and numbers as a guide to wire the new one. make sure if you make splices that you strip the wiring at least half to 3/4" and twist them together making sure BOTH wires are twisting, and screw a wire-nut, of the appropriate size onto the twisted wires tightly and make sure no wiring shows under the wire-but, it could touch something and short out.
Getting access to the controller is easy enough, just take the top part of the dryer apart, and keep track of how you did it and what screws go where as they will be different lengths and sizes. MOST IMPORTANTLY, make SURE the dryer is unplugged!, and TAKE YOUR TIME with the labeling of the wiring. Good luck, let me know how it goes!
Nov 10, 2009 | Whirlpool LER5636P Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Furniture Logo
42 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
