Question about Craftsman 1 Hp, 4 Gal. Air Compressor
Quits pumping at 40 pounds but compressor motor still runs
  • 365 Answers
Did you unlock the ring around the pressure adjustment knob? turn clockwise all the way and relock.
Good Luck
Posted on Jun 15, 2009
Auto leveler compressor of 97 Olds LSS can be replaced or install new strut assembly. Will be 2 mths before i can afford either. Can I pump air into the shocks and make it stay there?
My 05 lesaber compressor quit working and what caused it to quit was the old air struts wore out and made the compressor run all the time causing it to over heat and burn out. Rather than replacing the air shocks and compressor my mechanic installed a set of air shocks and installed an air line from them to a spot below the trunk lid on the bottom of the trunk. They have what looks like the air nozzle for a spare tire I use an air compressor or even the air pump you blow up a spare tire. I keep about 60 pounds in them all the time and check the air pressure abour every three months. Cheaper doing it that way.
Sep 23, 2017 | Cars & Trucks
I HAVE MY COMPRESSOR MAX AKHL1230E AND IT NEVER TURNS OFF IT JUST KEEPS RUNNING
Francisco:
Could be one of two reasons. If the compressor does not reach full pressure in the tank, you have an air leak somewhere between the tank and the business end of the hose. Run the compressor and use a soap and water solution to find the leak and correct it. Don't forget to check the copper line leading from the compressor motor to the air tank. My compressor would not pump above 45 pounds, and I had to replace the valve body (on top of the cylinder) because a valve had cracked.
Jan 20, 2016 | Air Tools & Compressors
I have a craftsman air compressor model number 921.153101 that won't pump-up over 40 pounds
Its probably a oil less compressor so it could be the reed valves are bad or the piston rings are bad.
Feb 01, 2014 | Craftsman Air Tools & Compressors
35 pounds of pressure in air conditioning system but 0 when compressor turned on
Detect refrigerant leakage in the system, repair and recharge the gas
Apr 08, 2013 | 2005 Honda Civic 1.7i
Craftsman 919.152920 air compressor shuts off
If you go to hammerwall.com and look up 919.1529 it will take you with a bit of mucking around to a Sears manual close to your model. Do not click on any of the big green download buttons. Click on the smaller blue message download bars. It tells you basically that your compressor has an internal overload which shuts the motor down if it overheats. the reason for overheating can be low voltage but also could be a stuck pump. To check turn off the power and diconnect the ppower cord from the wall. You should be able to turn the motor and pump with the drive belt. If the pump and motor will not move easily remove the drive belt and see if the motor and the pump turn freely on there own. If one or both are tight it will probably be the motor bearings if the motor is tight or the rings in the compressor if the pump is tight. It depends on your level of mechanical experiance as to wether you want to go further. Small 110v or 240v motors are a pain to pull down and the cost to repair are probably not worth it. If someone you know has a clamp tester and a test plug they could measure the amperage draw with the drive belt off and on. The amp draw should not be more than 10 amps even if you have a fiveteen amp circuit. The motor should have a sticker telling you what the amp draw should be. If all this info is getting beyone you I would suggest a visit to a serviceman for a quote.
Jan 15, 2013 | Air Tools & Compressors
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Campbell hausfeild air pump 26 gallon runs for an hour and only produces 40 pounds of pressure what could be the problem
Head valves. Some units use simple metal strips (reed valves) while others are just a bit more complicated. Could be either a broken valve or a stuck valve. The other possibility would be a stuck one way check valve that goes into the tank and keeps the pressure from going back into the pump.
Jul 15, 2011 | Campbell Hausfeld Air Tools & Compressors
What tpye of oil goes in the compressor
According to the Owner's Manual, 30 weight compressor oil is recommended. I'd use AMSOIL PCK, even though it's 40 weight. The pump will run cooler, last longer, use less gasoline, and require fewer oil changes. I'd also recommend AMSOIL's AFF 0W-40 Synthetic 4-Stroke Power Sports Oil for the motor for the same reasons.
Jul 16, 2010 | Chicago Pneumatic 30Gallon TwoStage Air...
Poter-Cable 135PSI Pancake Compressor
Check the pressure switch, they can become stuck in the open position. You can jump it to see if it is functioning or use a multimeter if you have one. Assuming that you've oiled and taken care of it it is unlikely that it simly quit, but that could happen... check across the poles of the motor for continuity which will tell you if the electric motor is blown. ALso make sure the compresor is not seized...
Jan 04, 2009 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Craftsman 1 Hp, 4 Gal. Air Compressor Logo
140 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
