Question about Sewing Machines
Proper lubricating of New Home HF106 sewing machine
How to oil machine
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
SOURCE: oiling Brother Ultima 2001 sewing/embroidery machine
The only place you can opil an ultim is inside the bobbin case and around the bushings in the front end. Do a search for Anns fix it and you will find more than you will ever need for these machines
Posted on Nov 08, 2009
  • 1116 Answers
SOURCE: How do I woke my sewing machine NEW HOME HF106
I found a download here - http://nowdownloadall.com/servers.asp?PID=0abb622d-3320-4687-bb07-c6e6385feac8&q=new+home+hf+106+sewing+machine+manual
I did not open to check it as I did not want to sign up to become a member of the site.
Your choice.
Posted on May 19, 2010
bargainbox
  • 1388 Answers
SOURCE: New home sewing machine model HF106 have been
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
SOURCE: oil for sewing machines
sewing machine oil,, you can get it at wal mart or hancock fabric
or order it online also
Posted on Aug 31, 2012
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
What kind neddle do i need for a New Home sewing machine Model HF 106
Janome sewing machine needles should work on your machine
http://www.sewingpartsonline.com/janome-hf106-sewing-machine-parts.aspx
or
just try good quality brand needles with this code: 130/705H
Jul 03, 2017 | New Home Sewing Machines
New Home HF106 Manual
Janome owns New Home. Try their site.. or call the help line.
Nov 03, 2012 | New Home HF-106
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
Your choice.
May 19, 2010 | Sewing Machines
What size bobbin does my janome HF106 take?
hi,
for your Janome HF106 the Bobbin case j01313zw fits the best. I have attached the image of the particular bobbin for your reference.Hope your problem is solved.Please rate my solution as helpful.Have a great day.73a41f6.jpg
Mar 09, 2010 | Sewing Machines
New home sewing machine model HF106 have been having problems with the bobbin thread bunching up, and now the needle felt like it hit something, while I was sewing and broke.
Oct 28, 2009 | New Home HF-106
I had not used my New Home Memory Craft for some
The old oil and lubricants are most likely in some stage of solidification and caused the machine to labor to turn. This causes the safety fuse to blow so that the circuit board does not overload.
Replacing the fuse is buried deep within one for the circuit boards and requires a knowledgeable service person to extract it and also address the reason the fuse blew in the first place so that it doesn't happen again.
Jul 10, 2009 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
