Question about Toshiba 32A43 32" TV
Volume increases on its own
Volume is uncontrollable with the remote
Toshiba volume increases by itself
This model do have a Remote Control right? Try to check that out... the remote could be the one setting the Volume up suddenly.
Mar 16, 2010 | Microsoft Windows XP Professional With...
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Having connected up my PVR915OT I am unable to increase the volume on the TV to a reasonable level of volume using the Humax handset- can you offer a solution please?
As far as I recall, the volume control on the PVR remote only controls the volume from the PVR. So, select the volume fully up (using the PVR remote) then increase the volume on the TV (using the TV remote) until it's as loud as you can stand. You can then adjust (decrease) the the volume to suit using the PVR remote.
Jan 13, 2010 | Televison & Video
The volume will automatically increase until the
YOUR VOLUME BUTTON MYBE STICKING I NEED TO KNOW THE MAKE AND MODEL ON TH TV
Aug 24, 2009 | Televison & Video
Sometimes volume won't stop going up when I press +/- control
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
Jun 04, 2009 | Logitech Harmony 520 LCD Remote Control
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Toshiba 32A43 32" TV Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
