Question about Thermaltake Computers & Internet
Asus p4p8000 deluxe
Opengl 1.3
How can i corredt this error ??
report to mojang and play the pe version for a while. or you can delete your minecraft file and download it again
May 23, 2014 | Kaltner.net Minecraft Mobile Admin
Hi, i tried installing angry birds and was informed that 2048x2048 texture is required and my maximum supported size is 1024x1024. I have a ASUS EAH4350 game card and would like to know can this card be...
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to hope this helps http://download.cnet.com/%7Bvalue=http://www.download.com/asus-agp-v7100-deluxe/3000-2108_4-68331.html
ASUS AGP-V7100 Deluxe Combo v44.03:The ASUS AGP-V7100 Series graphics cards were created to provide mainstream PC users with the radical 3D/2D graphics and video performance of the GeForce2 MX, the 2nd generation GPU from NVIDIA. With the AGP-7100 Series and its support for the TwinView architecture, ASUS has made available the most variety of models to support several dual display output combinations using RGB monitor, TV, or digital flat panel
also http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance. ... and save profiles for Direct3D and OpenGL applications ... CATALYST 3.8 adds new features and advanced, customizable options to ATI's industry-leading unified software suite. Gameplay, multimedia, 3D applications are extended
hope this helps
May 29, 2011 | ASUS EAH4350 SILENT-DI-512MD2-LP- ATI...
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
http://www.asus.com/product.aspx?P_ID=szSFtrap7crpBaQE
if: M2N - SLI Deluxe/Wireless Edition
http://www.asus.com/product.aspx?P_ID=0jMy2X8lKstYRvev
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Choosing a GPU
SAPPHIRE 100256L Radeon HD 4670 1GB
  • Chipset Manufacturer: ATI
  • Core clock: 750MHz
  • Stream Processors: 320 Stream Processing Units
  • Memory Clock: 2000MHz
  • DirectX: DirectX 10.1
  • OpenGL: OpenGL 2.0
  • HDMI: 1 via Adapter
  • DVI: 2
Although it only has a 128bit memory interface it makes up for this by the large amount of stream processors and the high core clock. It's cheaper than the 9600 and better.
Nov 02, 2008 | Computers & Internet
Ram capacity
This motherboard supports RAM upto 8 GB but 32 bit Operatin system give support 4 GB. To know more about the mobo follow the link below
http://www.asus.com/products.aspx?l1=3&l2=12&l3=30&model=175&modelmenu=1
Jul 04, 2008 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
Unlocking ati radeon x2300 video card for opengl
Wow they do sound like a bit of a pain to get the open gl working. Here is a site that i found that has step by step instructions. I hope this helps.
http://www.driverheaven.net/modtool/
Feb 29, 2008 | Computers & Internet
Computers & Internet Logo
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
