Question about Steamist TSG7 7.5 KW Total Sense Steam Generator - TSG-7 - Bathroom Steam Unit
Will not turn on
Took the cover off unit steam the set button works 3light go on no light at the controller
2 Suggested Answers
SOURCE: i have a steamist smc-150 control that won't power
Contact Steamist directly for manual, DIY troubleshoot, warranty, etc:
http://www.steamist.com/contact.htm
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 17, 2011
Unit will not turn off
Sounds as if the control board took a power surge.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
I get a error initializing scanner?
Background of issue- When 4345/M4345 boots up, amber light comes on under start button and the message "Initializing Scanner" is displayed. The unit will print but will not preform any scan functions.
Steps taken to try to resolve issue:
1. Updated firmware
2. Restored factory defaults
3. Took off cover in back of printer covering scanner controller board and reseated all cables
4. Took apart scan unit and cleaned (2)mirrors in scan head
5. Took off back cover of unit, reseated cables coming from scanner controller board
6. Ran Scanner Test, in menu (which everything functions properly)
Usually I would say scanner or controller board has failed but I had 3 M4345 come down with this issue in one week. The only resolve i've found for this issue is repetitively turning on and off the unit until it comes up without "scanner initializing" message. Once it comes up it functions 100% until the unit is turned off and issue will come back.
I'm at a loss here with so many units having same issue, open to any advice. I once took the formatter out of bad unit and put it in good one and it caused the issue in the good one but i'm double verifying this tonight. Thanks for any help.
Nov 17, 2010 | HP LaserJet 4345mfp Printer
Water drips from the steam wand when I'm trying to get water through the espresso. I have a starbucks barista athena. I took the top off....but cannot see how to fix it.
Mine had the same problem, and I was able to fix it. 1) Unplug the unit and allow it to cool. 2) Remove the 2 screws from the top of the unit, and take off the cover. There will be a ground wire attached to the top. You can set the cover off to the side with the ground wire still attached. 3) Rotate the steam valve until you see the hex screw that adjusts the location of the inner plastic stop relative to the outer valve knob. You will need to "tweak" the position of this inner stop relative to the outer knob to allow the steam valve to close a bit tighter. Be aware that there is limit switch that needs to be in off position or pump will come on as soon as you turn the unit on. There is also a hard stop on the inner plastic piece that prevents over-tightening of the valve. This is a bit of a touchy adjustment. I would suggest playing with the mechanism before you adjust it so that you understand how it works before attempting a fix.
Sep 25, 2010 | Estro Barista Athena
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
Thermasol Pro 150 - 25094. Doesn't work. I have a very simple controller. Just a gib gray button and four other led lights near the 15 , 30, 45, and 60 lights to set the time. I think I need to do the auto...
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
Mar 12, 2009 | Thermasol Steam Bath Generators - Ambiance...
Push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Pump won't shut off
Hi Shamin,
You have to replace the printed circuit card.
Mar 30, 2007 | Saeco Magic De Luxe Espresso Machine
Steamist TSG7 7.5 KW Total Sense Steam Generator - TSG-7 - Bathroom Steam Unit Logo
Top Steamist Electrical Supplies Experts
Craig Butler
Craig Butler
ray gallant
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
