Question about Olympus FE-280 Digital Camera
Blurry lenses Same problem exactly. I'm not sure what happened (maybe sand in the camera?) The camera now turns off to a black screen, If I push the botton to see ast pictures, the screen works again and lets me see through them. But If I go back to "take picture mode", the image they give me is all blurry and if I try to use the zoom, the camera turns off.
  • 1 more comment
  • costanza_nic Jun 15, 2009
    Sorry, I'm having trouble understanding what you mean. If I remove the battery, the camera won't turn on at all. Btw, what it means to start the camera without camera? Finally, If I press the powr button for even less than 10 seconds the camera turns off... (and when I turn it off again it has the same problems)
    Hi. I'm not sure what happened to my camera, (possibly some sand got in it) but It's not working anymore. Whwn I turn it on, it makes weird buzzes and gives me a black screen. whe I do succeed in getting teh screen back, teh image it gives me it's all blurry. Finally, If I try to zoom, the camera buzzes and turns off.
    Top Expert:
  • Olympus Master
  • 77,499 Answers
This sounds like you have gotten some kind of contamination inside the camera, it is blurry because the lens can't move to focus the image in a smooth manner, it is sticking. U can try taking this apart but based on my experience this is best left to a camera repair shop, there are lots of tiny parts and hidden screws, you can do more damage if you don't understand how it all goes back together, taking it apart is not easy, putting it back right is almost impossible for a DIYer.
Posted on Jun 15, 2009
    Scholar:
  • 95 Answers
Check if you got any leaks in side of the camera,if yo mean the SANDS inside,camera is very delicate one,and when it comes to lens we should handle it very cautiously,if there is a sand inside it you cannot clean it by yourself because every electronic part inside the camera is small and delicate so best is to give to service engineer.
buzzing sound from the camera means something technical problem,
here i listed out the problem.
BASIC TECHNICAL PROBLEMS:
  1. When the camera won't turn on, check the batteries. Connect camera to an AC adapter. Remove all batteries, disconnect AC adapter, wait a minute, reinsert batteries and reconnect adapter. Turn on camera. If the camera gets wet, turn it off if it's on. Remove all batteries and media. Let it dry completely for at least 24 hours before reinserting batteries.
  2. Step 2 If the camera is burning through the battery too fast, minimize your use of the camera's built-in LCD (assuming it has one) if it has a viewfinder you can use instead. The LCD is the biggest power drain on your camera. Use only heavy-duty batteries (look for ones that say they're suited to digital cameras). Ordinary alkalines won't cut it. Look into upgrading to rechargeable NiMH batteries. If you have or can get an AC adapter for your camera, always use it when downloading photos directly to your computer. If your camera uses PC Cards or SmartMedia cards, get a card reader that will connect to your computer. This will save battery life and improve data-transfer speed. If problem occurs during very cold conditions, warm the batteries in your pocket or hand just before inserting them into the camera and shooting.
  3. Step 3 Does the screen keep turning off? Check message display for explanation such as focus or lighting. Battery is low; replace or recharge. Some cameras have a power-save mode that shuts down. when battery is low. In some models, you may be able to take non-flash pictures with low battery. Battery may be too cold. Warm it to room temperature.
  4. Step 4 When the camera won't let you connect it with the computer, always use an AC adapter when downloading directly to a computer. Check with the camera manufacturer (try its Web site) to make sure you have the latest version of the necessary software drivers. If your camera connects via a serial (COM) port, check for serial-port conflicts. If you're using a FireWire cable to connect to the computer, turn the computer on, turn the camera on and then connect the cable between the two. Don't turn off the camera while the cable is still attached. If the camera won't recognize the media, make sure media is inserted correctly (this isn't always obvious with SmartMedia, for instance). Make sure media hasn't been write-protected.
  5. Step 5 The flash doesn't work. Check that batteries are fresh. Check that camera hasn't been set for no-flash mode. Give the flash time to charge before pressing shutter.
RATE me,if yo like!!!!
    President:
  • 1,383 Answers
Ok
first remove battery and memory card from camera.
Then start camera without camera.
Then reset all settings to factory defaults.
Press power button for 10 seconds then it reset.
  • kishor
    kishor Jun 15, 2009
    start your camera without memory card.
    Then go to setings in menu then reset all settings to factory defaults.
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
When I turn on my Camera, the screen turns blue and say Zoom Error in red writting, and it wont turn on, and the shutter will not shut!
This happens du to friction in the movement of the lense assembly. Did you happen to drop it in sand or on hard surface. If the camera if exposed to sand, just the cleaning of the lense assembly,( gears and the barrels) will solve the problem. But, if any damage is there then the complete lense unit needs replacement.
Jul 17, 2008 | Olympus Cameras
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
Blurry screen
If you got sand/water in unit, it may damaged the circuits. You may have it cleaned completely, which could cost as much as a new camera.
Sep 12, 2006 | Sony Handycam CCD-TRV68 Camcorder
Olympus FE-280 Digital Camera Logo
80 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
