Question about Hardware & Accessories
Porch light timer switch problem
I replaced my porch light switch with a Utilitech timer #0192773. I connected the hot, load, neutral, and ground wires. After restoring power, I checked the timer operation manually. The incandescent porch lights just flickered. I have tried 2 different timer switches and both incandescent and CFL lamps. Can you help?
  • 5,245 Answers
Utilitech digital timer
The timer could have been miswired.
Mar 12, 2014 | Hardware & Accessories
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 30, 2012 | Hardware & Accessories
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
Jun 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I the manual wiring doesn't match what I have in the switch box. This switch is to operate 2 outside porch lights., previously wired to a single pole switch as follows.. one black wire to one screw and 2...
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Dec 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I, too, only have 2 wires in my switch. It is not clear what to do with the 4 wires on the utilitech 0192773. Did not see the answer to the same question.
I wrote a page on the Utilitec 0192773
It shows how to wire the timer and shows the manual larger.
Timer-green wire connects to bare ground wire.
Here's what to do Switch has 2 wires.
1) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. These are the neutral wires. Connect timer-white to these wires.
3) If electric box does not have white neutral wires described above, then connect timer-white to bare ground.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Can you please provide instructions for connecting Utilitech Self-Adjusting Wall Timer- #0192773. My electrical box has only 3 wires 2 black and 1 green ground.
What you are describing is a wall electrical box for a "Wwitch Loop". What this means is that the power source (Hot and Neutral) go to the light first. What the electrician has done is run a wire from the light in which one wire is the hot leg from the source and the other one is the "switched leg" which runs back to the light as controled on-off power to it. The only legitimate way to use this timer would be to replace the wire from the wall switch to the light with a 3 conductor cable (3 current carrying wires and a bare ground or green wire). This would allow you to bring the hot and neutral along with the controlled "switched leg" as this time requires a constant source of power for the timer itself. Don't be tempted to let someone tell you to use the ground wire as a neutral. It is not safe to do that.
Sep 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
217 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
