Question about Microwave Ovens
Having problem with website www.dvo.com/campchef to redeam free
Bought camp chef and suppose to get cook'n with camp chef free
What Type of fuse in the magic chef mcd1311st microwave?
It uses a 15A or 20A ceramic fuse 1/4'x1-1/4", which is available from home centers, hardware stores, home improvement stores, and big box stores like Wal-Mart.
See my help files:
http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
http://www.microwavecontrol.com/doorsw.htm
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. (* on the tag in the cooking cavity or around the door frame or the control frame or on the back)
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 27, 2017 | Magic Chef Microwave Ovens
I have a magic chef microwave that heats well but when the door is closed it hums and get really hot on top while not in use. Eventually it will stop working all together until it cools down then I can...
This one actually sounds like the unit is cooking when the door is closed without blowing the fuse as it is supposed to do. Unplug it from the wall and let it cool down, which it probably already is. Put a cup of cold water in it, close the door and plug it in for one minute. Unplug it from the wall and check the water. Did it heat up? I'd bet that it heated the water up. Sometimes the cook relay sticks closed and it stays in cook mode. This condition is supposed to blow the fuse but really rarely it doesn't. I've only seen this happen 3 or 4 times out of about 14,000 units I have looked at in my career.
It would need a new control PCB and new door switches and probably a new magnetron.
Oct 11, 2013 | Magic Chef Microwave Ovens
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
It won't shut off without unplugging, i have tried the loc remedy , holding it in to cancel /reset it
If it's actually cooking when it shouldn't, it'll need to have the control circuit board repaired. Details on that are here.
If just the fan / turntable / light (or some combination of those) are on, but it's not cooking, then its probably a bad door switch or mount and this file will help you.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
May 04, 2010 | Magic Chef Microwave Ovens
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
I have a Magic Chef MCO153UB. When the unit is used to cook for 5-10 minutes you hear a distink change in the way it runs, the light stays on and the table still turns and the fan runs, but cooking stops...
Thanks for the great details about the light & turntable.
With that in mind, this is either a failing upper door switch, a failing relay or connection on the control board, or a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Another helpful link:
http://www.microwavedisplay.com/doorsw.txt
There should also be a helpful wiring diagram hidden inside the unit behind the control panel.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | Magic Chef Microwave Ovens
Cook time button problems
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Please reply back here and let us know if the hard reset doesn't fix it.
It may have a bad door switch, and we can help you check into that. The first test for that is to try it while gently lifting up and then while gently pushing down on the door.
If you don't have your owner's manual, you can download it here:
http://www.mcappliance.com/products/otrdetail.asp?record=yes&modelname=MCO153UB
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Magic Chef MCD1311ST Microwave Oven
LAST NIGHT OUR LESS THAN 1 YR OLD MAGIC CHEF MICROWAVE TURNED ON BY ITSELF AND WE TRIED EVERYTHING TO GET IT TO CANCEL INCLUDING UNPLUGGING IT SEVERAL TIMES. IT HAS A MIND OF ITS OWN NOW. MODEL #MC0160UB...
Have you looked on the magic chef recall website? I read about the same problem on the Samsung recall website about microwaves turning themselves on.
Apr 01, 2008 | Microwave Ovens
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
The problem is related to a thermal cutoff shutting down the unit due to the something (turntable motor?) overheating due to poor ventilation. You need to open the unit and ensure that all aeration opening are free of dust and grease. Compressed air works great for cleaning the internal components.
Regards,
Denis
Oct 09, 2007 | Microwave Ovens
Microwave Ovens Logo
142 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
