Question about Amana PTC153B50AJ Electric Heat Air Conditioner
PTC AC LEAKS WATER FROM FROUNT
HOLES CLEAN PULLED UNIT OUT OF WALL NEW CAGE OUTSIDE INSTALLED IN ALL CONDO UNITS..COULD LINE HAVE A HOLE
    Sergeant:
  • 340 Answers
Maybe u sure the pan is clean
Posted on Jun 20, 2009
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
Is all air conditioner split unit come with gas show me for free
Split air conditioner units usually do not come with the freon installed, because you need to run the hoses through holes in the wall to connect the inside evaporator with the outside pump and condenser.
So you drill the holes, install the units, connect the hoses, evacuate the air and moisture out, and then fill with freon.
Jun 06, 2011 | Hitachi NT50AGF 2Inch TCleat Oilless...
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
The refrigerator does not cool and a technician who came out said there was a hole in the line that is inside the wall of the refrigerator and we would have to replace the entire unit because it cannot be...
if the condenser coil runs through the refrigerator then it is possible a hole has developed but very unlikely you seen more restrictions instead of holes.... they do make a external condenser for units that can be attached to rear of unit...i didnt type your model number in but you have 2 coils a evaporator coil which is located inside the unit and is what cools the unit and then a condenser coil usually mounted under unit not internal or mounted to rear of unit visible to eye on back... now they do have a few units out there that were manufactured with the condenser coil internal if unit but a hole sounds odd.... how did the technician discover the hole did he pressure test system and hear inside unit or guessing strange sounding to me... like i said they do make external mount condensers but usually cost a fair bit to install... hope this helps you
p.s. was the technician a whirlpool o.e.m. authorized servicer from whirlpool just making sure you had a reputable person out and not some scammer ...wish you luck
Jan 27, 2011 | Whirlpool EL88TRRWS Refrigerator
We own a "converted" condo unit in a building that was previously apartments and now each unit is sold as a condominium unit. I have read about others having issues with cigarette smoke coming in through...
Hello,You need makeup "fresh" air intake vent added.You have a attic fan or when a clothes dryer,range hood,bathroom fan runs it pulls the house into a vacuum or negative pressure.It will pull air from anywhere it can to balance the pressure.Try leaving a window open a little bit for a couple of days(if you can do safely)and see if it works.Then you need a outside air vent installed.I assume the AC intake/return are seprate from the neighbors.
Oct 10, 2010 | Honeywell Electronic Programmable...
Dryer vent freezing , should I wrap it with something? or is it a leak in the wall?
the vent line is probably clogged with lint holding the steam in,it must be a long run from the wall to the outside hood,is there a cage on the outside to keep animals out of the vent line,if there is you gotta clean the cage out every month,remove the cage if one is there or if there isn't a cage try blowing out the vent line with a leaf blower,short bursts at a time,turn it on for like 5 seconds and shut it off,wait 5 seconds and turn it back on,if you have alot of lint in there and you don't have hard pipe you can pop a hole in the vent line with full power so take your time blowing it out,also there's a duct that your lint filter slides into,you have to clean that out too and vac the inside of the dryer,blow off the motor,it may look clean after you vac it but alot of lint gets stuck inside and under the motor making it run hot,you should do this or have someone come in at least once a year more so if it's gas with an open flame in the dryer so you don't have a fire,
Dec 20, 2009 | Dryers
The dryer does not heart
is it gas or electric?what's the model number?if you checked the thermal fuse located on the blower wheel housing and that's ok,check the heating element with a meter,if it's gas you have to read out the ignitor,the sensor and the gas coils with a meter,if it's gas and you have parcial heat change out the gas coils,did you check the thermal fuse part 3392519 or on some dryers it's a 3390719 with a meter,if you did you have to remove one of the wires to get a true reading on anything you're reading out,also unplug the dryer before you check these things,also when you clean out the dryer you gotta take off the duct that the lint filter slides into and vac out the inside of the dryer,if the vent line is long,i use a leaf blower to clean out the line,remove the line from the dryer and the wall,stick the blower in the hole in the wall and blow the line out from the wall to the outside hood and make sure nothing is blocking the hood like a cage,some hoods come with a cage so animals can't crawl up the line,if you have this you gotta clean the cage every month,if you need more help send model number and if it's gas or electric
Dec 19, 2009 | Kenmore Dryers
I have a problem with my dryer, it is leaking water from it, was wondering where it might be coming from, any suggestions? I just dried a load of clothes and notice some water leaking from under the dryer....
all the dryer does is move air,if the steam can't move to the outside from a blockage of some sort your gonna find water droplets building up on and around the dryer,you need to clean out the dryer and this should be done every year so you don't have a fire also more so if it's gas with an open flame in the dryer,if you have a long vent line run from the wall to the outside use a leaf blower to clean out the line,first run the dryer and check outside to see if the flapper is blowing fully open,if there is a cage on the hood,throw it away,all it does is collect lint,if you want to keep it go out and clean it every month,if it's low to the ground this is used so no animals can crawl into the line,now unplug the dryer,take off the front panel and vac out the inside,then clean the duct that the lint filter slides into,ge drums ride on a rear bearing and the heater is on the back wall behind the drum,if you look inside you'll see holes in the back wall of drum,if you have a shop vac put it on blow and blow out the holes in the back of drum,alot of lint collects in there,hope this helps,you definetly have a block somewhere and the is is being restricted
Dec 17, 2009 | GE Dryers
No Exterior vent for fumes
Hello kbender,
I am absilutely certain that the reason it vents inside is because it is more difficult to vent it outside.. ( which means it costs the builder more to do that) but to answer your question.. Yes, all spacemaker micros can be vented out the wall but you will have to remove it from where it is mounted and rotate the blower assembly so it vents out the back, place a blank off plate over the open area where it used to vent ( it may be there and needs to be repositioned when you rotate the blower) , then create a vent hole that lines up with the exit point of that micro.. and attach duct work to bring it outside ( depending on your siding , will dictate how that gets mounted externally and you may run into a problem witha stud on the outside wall ( a bearing wall) that wil need to be cut..I've installed many of these to outside vents and it is a lot of work.. so you may want to consider your options. If you hire someone, that's the easiest solution. You may also want to check to make sure your condo committee ( if you have one) will not have a problem with that.. or you may be able to get a group discount if you hire someone to do mulitple units..
Hope that helps..
Regards,
Rick
Dec 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Window to wall unit?
No, actually switching from window to wall is easier that vise versa. I don't know your can size versus the hole in the wall but you may have to enlarge it if its bigger or fill in the space with some wood trim on the outside and some molding or sheetrock on the inside. some insulation wont hurt either . the expandable foam is good for the wall space. Caulking for the cracks. pretty basic stuff. A good way to mount it is to slide the louvered can out and screw it to the wall, then its nice and secure. Unless its a very large and heavy unit, you shouldn't need any support struts on the bottom.
Jun 02, 2007 | Kenmore 70088 Air Conditioner
Amana PTC153B50AJ Electric Heat Air Conditioner Logo
140 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
