Question about DB BASS INFERNO BassInferno BI4200 Car Amplifier
Ken wood kac-846 not working
No power light
Stereo shut down
Did you check fuse block in the car as well as the stereo fuses?
When the face plate is down does that model have any indicator lights in the rest of the deck to see if it is getting power? My old ken wood used to have a red light that blinked behind the faceplate.
Sep 06, 2014 | Kenwood KDC-X993 EXCELON Flip-Face CD/MP3...
My kenwood amp doesn't light up, fuse is good
your amplifier has a power supply problem,contact Eric @ Capital Audio & Electronics Repair 850-339-1130 email poppa1puff@aol.com
Feb 01, 2010 | Kenwood KAC-529S Car Audio Amplifier
Kac-8101 no power
no its not dead u prob blew a couple of heat sensors or a capacitor. most defenetly a capacitor. ceck ur capacitor and see if its blowned
Jun 28, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Canon iR2200: ends PD-ME calibration with E-846.
A E-846 is a problem with the scanning lamp calibration. To resolve the problem you can do one of two things. First you will have to replace the scanning lamp & the scaner inverter PCB as a pair with the up-dated version PCB. Or if you have a parts machine, you can use a working scanning lamp with the PCB and replace them as a set or pair. You can not use a lamp from one copier and a pcb from another.. They have to be a matched set... Good Luck
May 12, 2009 | Canon imageRUNNER 2200
Kenwood KAC-9152D Car Audio amp
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Cooling fan light on My KAC-X401M
disconnect all power including ground for 20min
Jun 14, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
DB BASS INFERNO BassInferno BI4200 Car Amplifier Logo
23 people viewed this question
Top DB BASS INFERNO Car Audio & Video Experts
xxxxxx xxx
Are you a DB BASS INFERNO Car Audio and Video Expert? Answer questions, earn points and help others
