Question about Goldstar Refrigerators
Goldstar gc131cw manual
Problem with freezer valve
GOLDSTAR VHS VIDEO GHV-55FM NEED OWNERS MANUAL
Have a look at the Goldstar website, they might have a free PDF of the manual.
Mar 07, 2014 | Goldstar Televison & Video
HI, I'm Ricky, I have refrig goldstar GR-412HVM which can't make ice in the freezer and no cold in the lower part. Please help me TQ
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 07, 2011 | Goldstar GR131CN Compact Refrigerator
Air doesn't get cold like it use to. I spray cleaned the unit and it didn't help. Can the unit be recharged? Goldstar model: GWHD6507R Thanks.
Hello, yes the unit can be recharged but you need to install a piercing valve on tje low side of the system to charge in the refrigerant here is a link to where you can buy piercing valves. http://www.globalindustrial.com/g/hvac/parts/ac_accessories/Supco-Acces-Valves
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Goldstar GR542WV refrigrator is not cold in both the freezer and the storage compartment.
hello,
try turning the breaker off for several minutes, if the compressor does not fire up the control on the back will need to be replaced. I have seen this issue several times on this model, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Goldstar Refrigerators
Stabbed my 1986 goldstar freezer
Well, yes, but not because of the gas. We all gotta go some time. LOL. You were exposed to a small amount of R12 refrigerant. It is NOT toxic. Sure massive exposure (depleating your O2 supply) would not be good, but you'll be fine. Relax. Buy yourself a new freezer and rate me a FixYa.
Oct 22, 2008 | Goldstar Refrigerators
Refrigerators Logo
189 people viewed this question
Top Goldstar Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
