Question about 94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert
No fluid to r/f caliper 96 silverado
Both wheel cylinders replaced and calipers and front brake hoses
  • Chevrolet Master
  • 753 Answers
A collasped rubber brake hose or your antilock module is blocking that circuit.
Posted on Sep 16, 2014
How to fix1977 corvette stuck front caliper?
replace both calipers and bleed system. remove wheel, unbolt brake flex hose where it mounts to the caliper,clamping hose to keep from losing brake fluid, unbolt caliper from caliper mounting bracket. and remove caliper. re-install in reverse order bleeding front brakes making sure master cylinder doesn`t run out of brake fluid.
Sep 03, 2014 | Cars & Trucks
How do i remove the brake caliper on a 1994 f350 4x4 there are no bolts attaching it
If this is a Pin Slider, here is 1996 steps:
Section 06-03: Brakes, Front Disc 1996 F-150, F-250, F-350 4x2, 4x4, Bronco and F-Super Duty Vehicles Workshop Manual
REMOVAL AND INSTALLATION Caliper
Heavy-Duty Rail Slider, F-Super Duty
Replace brake shoe and lining (2001) as follows when the lining is worn to a minimum thickness of 0.794mm (1/32 inch) above the front disc brake rotor shield. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always replace all brake shoes and linings on an axle. Never replace only one wheel (1007).
Removal
  1. To avoid fluid overflow when the caliper pistons are pressed into the caliper cylinder bores, siphon or dip part of the brake fluid out of the brake master cylinder reservoir (2K478). Discard the removed fluid.
  1. Raise the vehicle and install safety stands. Remove the front wheel and tire assembly.
  1. Place an appropriate size C-clamp on the disc brake caliper with end of clamp against caliper and end of screw against outer shoe. Tighten the clamp to bottom the caliper pistons in the cylinder bores. Remove the clamp. Do not use a screwdriver or similar tool to pry caliper pistons (2196) away from the front disc brake rotor (1125).
  1. Clean excess dirt from area around pin tabs.
  1. Tap upper caliper pin toward inboard side until pin tabs touch the front wheel spindle.
  1. Using Hydraulic Caliper Pin Remover D89T-2196-A or equivalent and a light hammer, drive the pin from the disc brake caliper as follows:
    1. Position the notched end of the tool against the caliper pin (retention tab half), at a 45-degree angle from the pin retention tabs.
    1. Tap the tool with the hammer to compress the retention tabs.
    1. As the retention tabs are compressed, move the tool to gain a straight approach to the caliper pin, and continue tapping to drive the caliper pin through the caliper/spindle groove.
  1. Repeat removal procedure for lower caliper pin.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not let the disc brake caliper hang by the front brake hose (2078). The front brake hose could become stretched or twisted which can cause the front brake hose to leak and rupture, resulting in failure.
    Remove the disc brake caliper from the front disc brake rotor. If the disc brake caliper is to be removed for service, remove the front brake hose from the disc brake caliper. Plug the end of the front brake hose to prevent fluid loss and entry of air into the system. If the disc brake caliper is not to be removed, wire it up to the frame of the vehicle to avoid damage to the front brake hose.
Installation
stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always replace all brake shoes and linings on an axle. Never replace only one wheel.
  1. NOTE: There is a raised section at one end of each shoe so installation can be made in one direction only.
    Install new inner and outer lining.
  1. Lubricate the knuckle upper and lower inner pad grooves and caliper grooves with Disc Brake Caliper Slide Grease, Silicone Dielectric Compound D7AZ-19A331-A or equivalent meeting Ford specification ESE-M1C171-A. Install the disc brake caliper on a front wheel spindle, making sure the mounting surfaces are free of dirt.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not allow the tabs of the caliper pin to be tapped too far into the spindle groove. If this happens it will be necessary to tap the other end of the caliper pin until the tabs snap into place. The tabs on each end of the caliper pin must be free to catch on the spindle flanks.
    Position caliper pin with the pin retention tabs oriented adjacent to the spindle groove.
  1. Tap the caliper pin on the outboard end with a hammer. Continue tapping the caliper pin inward until the retention tabs on the sides of the caliper pin contact the spindle face. Repeat procedure for the lower caliper pin.
Oct 23, 2011 | 1994 Ford F350 Crew Cab
I have a 96 isuzu rodeo,3.2 and the brakes will lock up on their own, gradually then it takes about 15 minutes for them to release, any thoughts?
this could be caused by a few things, first you need to jack the truck up you will need all 4 wheels off the ground, put the transmission in neutral and have some one get in the truck and wile turning each wheel have the person in the truck push the brake pedal the wheel should stop instantly then have the person release the brake the brake should release instantly,( do this to each wheel ) if all brakes remain locked ( wont release instantly ) then replace the master cylinder if the both rear brakes wont release instantly replace the brake hose from the frame to the rear differential, if the both front brakes wont release replace master cylinder, if only one front brake wont release open the bleeder on that brake caliper if the wheel releases replace the caliper hose if the brake still wont release with the bleeder open replace the caliper, you should replace the caliper and brake hoses as a pair.
Mar 02, 2011 | 1996 Isuzu Rodeo
95 chevy silverado, brake fluid was contaminated and master cylinder went out. Replaced master cylinder and flushed out all of the bad fluid. Now the front breaks are locking up when applying medium to...
Hello: You nare going to have to replace/rebuild front calipers, replace Both rubber hoses that go fron the frame to the calipers. You may have to replace the rubber hoses in the rear and the rear wheel cylinders. Contaminated brake fluid creates a expensive and long repair.
Jan 10, 2011 | Chevrolet 1500 Cars & Trucks
2006 chevrolet 1500 brakes shimmy without touching them,also when setting still mash couple times let off ,wheels hard to turn
check for front brake calipers dragging, if the are replace calipers and front brake hoses, if calipers ok replace master cylinder, This is how to check calipers, jack up front of truck have some one apply brakes and release as soon as they release the brake peddle the wheels should spin freely if not brake the brake line lose at master cylinder if wheels spin free with line loose replace master cylinder, if not replace calipers and hoses.....HOPE THIS HELPS
Nov 16, 2010 | 2006 GMC Sierra 1500 2WD
How do you replace the front and rear brakes in a 2003 pontiac Grand Prix
Removal & Installation Front To Remove:
  1. Inspect the fluid level in the master cylinder reservoir. Remove fluid from the reservoir until the level is lower then half way between the MAX and MIN levels.
  2. Remove the tire and wheel assembly.
  3. Install 2 wheel nuts to secure the rotor on the hub.
  4. Remove the bottom brake caliper pin bolt.
  5. Pivot the brake caliper body upward and secure out of the way. Do NOT disconnect the hydraulic brake flexible hose from the caliper.
  6. Compress the piston back into the bore using a C-clamp. Figure of brake assembly with caliper raised showing brake pads in mounting bracket gmpc_l4.gif
  7. Remove the inboard and outboard brake pads from the brake caliper bracket.
To Install:
  1. Install the brake pad retainers and both brake pads into the caliper bracket.
  2. Pivot the brake caliper down over the brake pads and into the brake caliper bracket. Insert the lower brake caliper pin bolt and torque bolt to 70 ft-lb. (95 Nm).
  3. Reinstall the tire and wheel assembly.
  4. Lower the vehicle.
  5. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  6. Check the master cylinder level and add fluid as necessary.
Rear To Remove:
  4. Remove the upper caliper mounting bolt.
  5. Pivot the caliper down to access the pads.
  6. Remove the inboard and outboard pads from the caliper bracket.
  7. Remove the brake pad clips from the caliper bracket.
  8. Compress the piston back into the bore using a C-clamp and the old inner pad.
To Install:
  1. Install new brake clips in the caliper bracket.
  2. Install the inboard and outboard pads in the caliper bracket.
  3. Pivot the caliper up over the pads.
  4. Reinstall the upper mounting bolt and tighten to 32 ft. lbs. (44 Nm).
  5. Remove the 2 wheel nuts securing the rotor.
  6. Reinstall the tire and wheel assembly.
  7. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  8. Check the master cylinder level and add fluid as necessary.
Aug 26, 2010 | 2003 Pontiac Grand Prix
Silverado 1500 Z71 off road, 5.3L. Details on fr
This is for the front: Removal & Installation
  1. Remove 2/3 of the brake fluid from the master cylinder.
  2. Remove or disconnect the following:
    • Wheel
    • Caliper. Suspend the caliper from the frame with mechanic's wire. Do not allow the caliper to hang from the brake hose.
    • Caliper mounting bracket bolts
    • Caliper mounting bracket from the steering knuckle assembly
    • Brake pads from the caliper mounting bracket
    • Clips from the inside ends of the caliper mounting bracket and discard
To install:
  1. Install or connect the following:
    • Clips to the inside ends of the caliper mounting bracket
    • Brake pads to the caliper mounting bracket
    • Inner pad (1 wear indicator)
    • Outer pad (2 wear indicators)
    • Caliper mounting bracket to the steering knuckle assembly
  2. Perform the following procedure before installing the caliper mounting bracket bolts:
    • Remove all traces of the original adhesive patch.
    • Clean the threads of the bolt with brake parts cleaner or the equivalent and allow to dry.
    • Apply red Loctite®272 to the threads of the bolt.
  3. Install or connect the following:
    • Caliper mounting bracket bolts to the steering knuckle. Tighten the caliper guide pin bolts to 74 ft. lbs. (100 Nm) on 15 series or 80 ft. lbs. (108 Nm) on 25/35 series.
    • Caliper
    • Tire and wheel assembly
  4. Refill the master cylinder to the proper level with fresh brake fluid. Pump the brake pedal slowly and firmly in order to seat the brake pads. Burnish the brakes as needed.
Oct 12, 2009 | 2003 Chevrolet Silverado 1500
2001 silverado 1500, just put on new pads rotors and 1 new caliper, the brakes are spungy, the wheel with the new caliper is sticking and the front passanger brake too, i cant figure out why.
Replace both front brake hoses.....they collapse on the inside and will not allow fluid to retract...caliper was probobly fine.....this happens a lot....good luck...Lee
Jul 22, 2009 | 2001 Chevrolet Silverado 1500
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
Installation
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
I need to know how to bleed the brakes on a 1999 chevy blazer
Start from right rear, then, left rear, right front, left front. Fill master cylinder. Have helper sit in car, have helper hold brake pedal down. open bleed screw. fluid and air comes out. close screw. release brake pedal. Continue until no air comes out. Move to next wheel. Keep an eye on master cylinder fluid level after each wheel.
Mar 27, 2009 | 1999 Chevrolet Blazer
94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert Logo
87 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
