Question about Janome Memorycraft 9700 Computerized Sewing Machine
Embroidery arm makes noise
The are does not move and ma's grinding noise.
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
Embroidery arm does not work
Sounds like the embroidery arm belt stop is out of adjustment. Unless you're pretty handy, take the machine and arm to a professional. If you're going to tackle it yourself, get a service manual for the machine.
Mar 21, 2014 | Husqvarna Designer I
Embroidery Arm is not moving right/left
Check to notice if when the embroidery arm is installed and you turn the power on does the embroidery unit move as it calibrates the stepper motors. If not I would first check the plug where the machine and embroidery unit attach. If this looks ok and is not out of place it could be a cable, or the main circuit board. Both of those are for your dealer to repair.
Feb 08, 2014 | Husqvarna Sewing Machines
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
CONNECTING THE ARM AND IT MAKES A GRINDING SOUND WHEN TRYING TO DO ALIGNMENT
While the embroidery arm makes a certain amount of noise when it is initially indexing, I'm assuming from your description that the mechanism is making noise but ends up stalled (probably with the hoop holder in the rearmost position). It sounds like it's not engaging the end stop switch correctly. Take it in for adjustment. This is not something you want to tackle yourself. Beyond the switch adjustment it may additionally require recalibration to properly register the various hoop sizes.
Dec 17, 2012 | Husqvarna Designer I
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
Open Questions:
See all Janome Memorycraft 9700 Computerized Sewing Questions
Janome Memorycraft 9700 Computerized Sewing Machine Logo
24 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
