Question about Dell 1355cnw AllInOne Led Printer
Roller is making a noise
When printing the roller is making a noise.
2 Suggested Answers
  • 5 Answers
SOURCE: Rollers make a loud noise when printing...do we
Does it make a groaning sound, when picking up the paper from the cassette tray? If it does, sounds like you need to order a set of feed rollers. You can tell if there worn down, just by feeling if there's still some treading, just like a bald tire. Good Luck!
Posted on Jul 30, 2010
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
Printer HL-3070CW - LOUD Grinding noise when it seems to be running large print offs. It is almost like it gets too hot
My 3070CW makes the same noise. It is caused by the transfer belt. One roller is driven by a cog and this goes fine. The other roller has a tensioner and this roller is making all the noise. While the noise is really loud and annoying - it is completely harmless. Hope this helps.
Aug 09, 2011 | Brother HL 5250DN Laser Printer
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
Mar 18, 2009 | Samsung CLP 300 Laser Printer
Noise from HP LJ 1020
Change the gears , coz when the machine load or when you are printing the roller turn, and those roller has gears at the ends so when they are died they give those sounds, open the cover and try to detect which gear make this noise and change it.
Mar 01, 2009 | HP LaserJet 1020 Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Printer is not working.
There are several things in the front that could be making that noise.The transfer roller,paper guide/top ublique roller and front obligue roller which is on the left side front. It is hard to say. I guess the printer is printing OK. If not what is the printer doing? Do you get any paper jams? Printing light? Can you rub the print off the paper? Any labels stuck? Please answer questions so I can help you. My guess is a roller problem. Which one is hard to say since I can't hear the printer myself.
Jan 13, 2008 | HP LaserJet 4L Printer
LOUD thumping noise when printing
Fuser/ upper heat roller/film or lower pressure roller has lost it's coating, nees new fuser assembly (hot bit at back) about $150 plus labour
Oct 12, 2007 | HP LaserJet 1300 Printer
Dell 1355cnw AllInOne Led Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
