Question about Krups FBC2 1600 Watts Toaster Oven with Convection Cooking
Heat elements on top quarts are not light up
No matter what cycle we try. Bake or broil, bottom quarts are Red but top quarts heat elements are not working.
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Hamilton beach 31197
Look for the thermal cutoff. Either it looks like a resister or it looks like circular thing. Test it for continuity
Oct 18, 2013 | Toaster Ovens
The heating elements on top do not come on to toast or bake the topside. The bottom elements heat up just fine. How do I troubleshoot? Is it worth fixing?
The following phone number will connect you with service department of Black and Decker and maybe they can tell you if it is cost effective to repair or if you should just buy a new one.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Mar 22, 2011 | Black & Decker TRO910W Toaster Oven with...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Krups FBC2 1600 Watts Toaster Oven with Convection Cooking Logo
49 people viewed this question
Top Krups Toaster Ovens Experts
warcraft demonhunter
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
