Question about Cuisinart CMW-100 Microwave Oven
Microwave door does not latch
How to fix door latch
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
Frigidaire Mod: FGMV174KFB Door won't latch
Good Morning Friend,
I understand the door will not latch on your Frigidaire microwave, model# FGMV174KFB. Typically, this would not be a do it yourself repair, as you are working with your microwave, and there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the latch on your door with ease. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
Inside door latch broken on my Sanjo microwave EMD9552
Hi, For any repairs involving door latches on microwave ovens, I strongly urge you to get a certified service technician to replace and adjust the door for you as he should have a leak detector to verify the fix. Not performing the leak test could expose you/your loved ones to harmful microwave energy if not setup correctly
Dec 08, 2012 | Sanyo Microwave Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
The micro wave door is warped so that the top right latch will not fully engage. How do I fix it?
If the door is warped, buy a new microwave but that is very unlikely.
Release the lower hinge screws and square the door up to the latches then tighten the fixing screws.
Hope that helps.
Jan 12, 2011 | LG LMV1630ST Microwave Oven
Door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
Microwave door doesn't shut
I answered this personally via e-mail (and I do not mind peopke writing me personally). I think you may have a broken tab which holds the door latch head spring in place.
Oct 19, 2006 | Sharp R-1481B Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
