Question about Dell Dps-350mb N Power Supply Delta 350w Pws For Pe3250 0p1126
Need pinout and pin explaination. - Dell Dps-350mb N Power Supply Delta 350w Pws For Pe3250 0p1126
Need pinout for power supply alesis 1622 p4
they have one already make 5 pin to 4 pin 3 dollars computer shop
Dec 20, 2013 | Asrock P4i65G Motherboard
The 8 pin connector to the cluster got accidentally dismantled and all the 7 wires in the sockets popped out. I do not how to put them back as the wires do not have numbers corresponding to the plug.
Hi.
The pinout depends on year and model of the Mercedes. Models between 1988-1993 used the following 8-pin diagnostic.
8 pins diagnostic.
There are also several 8 pin connectors used in Mercedes radio and CD. Here the pinouts.
Regarding the connector at the back of the dash, to find pinout I will need year and model of the car.
Jun 08, 2011 | Mercedes-Benz 560-Series Cars & Trucks
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Apr 24, 2009 | Audio Players & Recorders
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Dell Dps-350mb N Power Supply Delta 350w Pws For Pe3250 0p1126 Logo
76 people viewed this question
Alun Cox
