Question about General Electric WJRR4170GWW Top Load Washer
Have a wjrr417og1ww washing machine. it is about
Have a wjrr417og1ww washing machine. it is about 1 yr old, just stopped spinning or aggitating...it will fill, run its time and drain, but tub does not move. no humming or any noise, other than the clock ticking...do you think that magnetic switch on the lid is not working? help
  • 4 Answers
If ther was a power surge or power went out machine needs to be reset unplug for 1 minute then replug unit in and open lid 6 times in 12 seconds it should reset . that is what i had to do with mine
Posted on Jun 26, 2009
  • 11,896 Answers
Check to see if the motor is spinning the belt. If the motor is not spinning, check to make sure there are not loose or broken wires. you can use a mutli-tester or ohmmeter/voltmeter to check any relays and fuses. If all fuses and relays are good, check to see if there is power coming from power supply to motor. If there is power, the motor is bad, if there is not power, the power supply may be bad.
Posted on Jun 15, 2009
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 9 times pauses and flashes 1 more time. Thanks in advance
My Washer stopped while washing and will not spin drain or aggitate.
It will power on and off I can change the settings but nothing happens.
Oct 26, 2013 | Washing Machines
The washing machine doesnt aggitate
the first thing to check is your lid switch.
does the unit drain or spin?
you may need to check your drain pump to see if anything is stopping it.
you should also check the wiring from the motor to the timer.
Mar 25, 2010 | GE WBSR3140DW Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stopped aggitating and spinning
it was the motor coupler. I replaced that and all is good.
Feb 16, 2009 | GE Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
General Electric WJRR4170GWW Top Load Washer Logo
439 people viewed this question
Top General Electric Washing Machines Experts
Marvin
Marvin
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
