Question about Ovens
F101 error code
Zanussi
I can not find a manual for model number ZE0505X
Susan, in what country did you buy the oven? The codes differ per country.
Does the model tag look like this?
Of course it might be difficult to FIND the tag...
Let me check where they stick those....not-find-manual-model-number-ze0505x-cluqxvqmjdhmibjs3bae0uvv-4-2.png
See above location in red.
You can lookup manuals on zanussi.com by using the PRODUCT CODE as well (the serial number does not help). Check if the product code gives you a result on this page:
http://www.zanussi.co.uk/Support/Manuals/
May 18, 2015 | Zanussi ZHQ575 Electric Double Oven
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
F908 ERROR CODE
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number and also the condition when this error occurs. Can you operate the oven after this fault occurs. Try to turn off the mains power and check after turning back on.
Jul 31, 2014 | Zanussi Ovens
Zanussi double oven switches off during cooking. It can be restarted without a problem so fault can not be detected. It displayed error 3 message once.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Dec 02, 2010 | Zanussi Ovens
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
Jul 11, 2010 | Zanussi Ovens
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
How do i fix error code F04 on Zanussi ZPB1260 single oven
Error Code F04 is due to the mismatch between the incoming line voltage and the voltage setting of the oven. To correct the error code follow the instructions given below : a) Make sure the line voltage corresponds with the setting of the oven. The voltage selector is located at the back and consists of two plugs. The white plug sets the oven for 208 V and black plug (or white plug with a black dot) sets the oven for 230 V. b) Make sure the line voltage is within +/- 10% tolerance. This is especially important during summer months, where line voltage has tendency to drop. c) If both steps above check OK, the error(s) may be caused by defective controller (DPU) board.
Jan 20, 2010 | Ovens
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Zbs 1063 - POBERR 80
Take note of the error code(POBERR 80) and contact an authorised
Service Centre.
Nov 24, 2007 | Zanussi ZBS963X Electric Single Oven
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
