Question about Tetra Whisper Ex30 Power Filter - Products
Filter is not quite
Makes a rattling sound, just bought the unit
My 2004 Prius has a rattling metallic sound on acceleration. It is coming from the top of the engine on the passenger side. Does anyone know what this can be?
Does the car make this sound when the car has just been turned off and engine is still hot? Lightly push the car back and forth while it's in park. Does it still make that sound?
Sep 23, 2012 | Cars & Trucks
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
2006 Camry 2.4L 4 Cylinder inlet manifold rattle
quick fix and cheap drain a quart of oil out of the motor then get a quart of LUCUS oil conditioner add to the motor oil. about (12-15 dollars) it worked to quite the little 2.0 that has always had a little lifter/valve noise,
Jun 03, 2012 | 2006 Toyota Camry 2.4
I bought this blower last week,i tilt it alittle and heard a rattle sound and now it wont start
Check the fuel filter in the tank and make sure the fuel line is connected to it. The carburetor may have inhaled some debris and/or small chunks of broken fuel line and need to be opened up and cleaned also. At this point, you would probably need to install a new fuel filter also.
Jan 15, 2011 | Weedeater 25cc Gas Blower ()
Speed Queen CTSAOAWN front loader, makes quite a bit or noise (more than it used to ) when in spin cycle -- rattling, scraping sounds. I'd like to open the front of the unit to see if any suspension...
take front lower panel off.. there will be a white filter housing facing you unscrew abs /plastic clean out usually pennys /dimes quarters put back the same way you took off bingo problem solved<!-- from fixya rte -->
Jul 27, 2010 | Speed Queen CTSA0AWN Front Load Washer
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Lots of water in unit spitting all over the floor and loud rattle
If it is rattling when in either fan or cool, you are having either a fan motor problem or the blade is hitting something. The water may be from a clogged drain port (by coil) which u are not seeing, if a new one is under 250, that is your best bet!
Aug 05, 2009 | GE Heating & Cooling
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Lg 1030hr excessive ping noise
COULD BE ALOT OF THINGS BUT MY FIRST GUESS IS THE FAN SCREWS THAT HOLD THE FAN MOTOR COULD BE LOOSE CAUSING IT TO RATTLE ON START UP OR SHUT DOWN BUT REALLY NOT MAKING TO MUCH NOISE AS THE UNIT IS RUNNING. CAN YOU DESCRIBE THE NOISE BETTER? IS IT SCRAPPING LIKE A SCRUB OR KNOCKING LIKE HIT HIT HIT HIT?
Nov 23, 2007 | Heating & Cooling
Rattling noises and blowing water (goldstar WG5005R)
If the unit is new and tilted enough toward the outside, the rain should not be a factor as far as water blowing out. It will make some rattling noises on the outside more so when its raining or high humidity because the outside fan throws water onto the condenser coil. Sounds like to me that its not draining to the outside.. It shouldn't be dirty enough for the drain paths to be filled with crud. Tilting it more to the outside should fix it. Hope this helps. kstfas
Aug 26, 2007 | Heating & Cooling
Tetra Whisper Ex30 Power Filter - Products Logo
Top Tetra Fish Experts
Jerry Kramer
Jerry Kramer
Steve Dearman
Level 1 Expert
Are you a Tetra Fish Expert? Answer questions, earn points and help others
