Question about Husqvarna 326LS
Husqvarna 5089014 blade installation
How to attach the blade to the weed eater
SOURCE: how to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Posted on Jun 08, 2009
bbreton
  • 437 Answers
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
stmc97
  • 41 Answers
SOURCE: what is the oil to gas ratio for the husqvarna
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Posted on Apr 11, 2010
  • 8 Answers
SOURCE: my Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Posted on Apr 27, 2010
  • 198 Answers
SOURCE: my husqvarna 125L weed eater will only run with
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
Posted on May 10, 2010
Weed eater one drive chain comes off
The problem with the chain Is the tensioner. There is not much the small spring can do. You may try to add tension to the chain but, not a good design.
Jul 20, 2014 | Husqvarna WE261 960220007 26 190CC Weed...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Engine dies when blades are engaged
sounds like one of the safetey switches are not working
Mar 22, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Blade on my weed eater troy build
I would suggest that you obtain a blade that fits. Reducing the mount will be dangurace
Jan 26, 2009 | Troy Bilt Tb70ss Gas Trimmer
Husqvarna 326LS Logo
27 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
