Question about Zilla Bulb Desert 50 UVB Fluorescent 20w Coil
Do you use desert UVB fluorescent 20 bulb at night
I just got a beardie and I have a basking light and a UVB fluorescent bulb I just don't know when to use them
Can I be sent a replacement bulb?
Direct your inquiry to the purchase source.
Aug 08, 2015 | ALL LIVING THINGS Neodymium Basking Bulb
I think my iguana has a broken arm. There is no reptile vet's in my area. I didn't know what to do
What part of the arm...most limbs heal by themselves and although the iguana may be slightly deformed for life they do fine ...as long as the proper diet and lighting is provided.
LIGHTING: You must provide a UVB specific lamp so the iguana can process the calcium in the diet to make bones strong.....no UVB lamp = weak and broken bones and deformities. Thats why they bask in the sun ...to get the UVB rays and process the calcium. Look up the disease called Metabolic Bone disease in reptile (MBD)
Go to the Green Iguana society to learn so much more ...care ...diet ... lighting.
Go to Mega Ray (Reptile UV) and order a proper lamp....100 watt SB (self ballast ) 120 volt or get a ZOO MED POWERSUN 100 watt -160 watt.
If your iguana already has signs of MBD they can be reversed with the proper diet and lighting. Don't become another statistic...research info about the proper care......and try to arrange some out door time in the sun ...early morning or late afternoon....20 minutes in the sun is equal to about 8 hrs under a man made lamp, so I have been told.
Good luck
Tips for New Iguana Owners
Welcome To ReptileUV Mega Ray UVB lamps for reptile lighting worldwide
Mega Ray 100 Watt Self Ballasted Flood UVB Lamp 100 46 95 ReptileUV...
Zoo Med Zoo Med PowerSun UV Mercury Vapor UVB Lamp Reptile Mercury Vapor
May 26, 2014 | Reptile
Switch doesn't work
Because the switches have electronics in them the ground wire may be very important to give it a full 120 volts to be able to run. Also double check your lighting, these dimmers are likely for incondescent lighting only (light bulbs). A compact fluorescent or some other lighting may blow the switches. If your lights are led they may not have sufficient resistance so that the dimmer knows that you have any lighting at all. Fluorescent lighting has to high a capacitive reactance and or inductive reactance. Halogen or other lights may cause troubles too. Check the directions on your switches to see if they were for incondescent only or for fluorescent only etc. Also modern bulbs don't seem to screw far enough into the sockets because of their fat necks that bottom too soon. You may have to turn off the power then put your finger inside to bend the bottom contact up enough to touch the bulbs.
May 04, 2013 | Cooper Wiring Devices Aspire Dimmer...
Flouresent light wiring diagram
tech specs? model etc any pics, this is standard usually only one way but it does depend
'------------------------------------------------------power'+++++++++++++hot++++++++++++switch+++++powermore questions just ask
Mar 29, 2013 | Original Equipment Manufacturer 20 Watt...
Lutron s-600 don't seem to function
That switch says on it that it is for fluorescent lights only. I don't know if you can use compact fluorescent bulbs on that system, perhaps verify if you can or not. The switch has electronics in it and may need that ground wire to get 120 volts to operate. If you have incondescent light bulbs return and get the correct dimmer.
Mar 16, 2013 | Lutron S-600-wh Skylark Incandescent...
What are the heating requirements for a ball python?
Ball pythons require a daytime temperature ranging from 80-85F and a basking spot of 90F. These temperatures can be slightly decreased at night to around 74F. I would recommend buying an under tank heating pad as well as an incandescent bulb for the basking area. You will need to use a minimum of two thermostats to help monitor the tanks temperature.
Sep 04, 2012 | Aqueon Reptile
What kind of lighting is needed for fire belly toads?
Fire belly toads should not be exposed to too much UVB light. The best way to control this is to use a fluorescent reptile lamp specifically designed for frog habitats that emit 3-6% UVB light. This bulb will need to be replaced every 6 months.
I need to replace old 60-watt incandescent light bulbs in fixtures that are covered by glass domes. A hardware store man once told me that the new fluorescent bulbs would not be good because they...
you could go and get led light to fit them, they are very good and they give off very little heat, a little expensive but in the long run it will be better than the currly q lighting
Aug 22, 2011 | Verilux Home
Zilla Bulb Desert 50 UVB Fluorescent 20w Coil Logo
61 people viewed this question
Top Zilla Reptile Experts
windryder
Level 1 Expert
john h
Are you a Zilla Reptile Expert? Answer questions, earn points and help others
