Question about Panasonic Televison & Video
Panasonic VHS VCR Playback mode Tape Stuttering between LP and SP
Hi,I have about a 5 year old Panasonic VHS VCR.During playblack the screen will alternatingly produce an image and then go entirely blue .Is this a feature called "VIDEO MUTE"?During this time when it is trying to play the tape the tape speed indicator will rapidly alternate between LP and SP :back and forth,back and forth.I cannot get a tape to play any longer.
  • Panasonic Master
  • 458 Answers
This is most because the control head may be dirty, this haed picks up the pulses from the tape to regulate the speed & tracking if this is off it can produce both the faults you describe. Also it is possible the pinch roller (black roller on the right hand side of the deck mechanism, sits just in front of the control head), this may be worn especially as the machine is five years old, this will cause the tape to guided off alignment.
Posted on Jun 23, 2009
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
I no longer have the original remote for my Samsung TV/VCR combo and am using a universal remote. Yesterday I started having problems with the speed of the VCR playback. Mostly, it is too slow, distorting...
U have play back problems on playback SP LP SLP modes tuggles problems.Try website like Remotes.com to buy the tv original remote,have these buttons to set the correct VHS tape play back modes tuggles problems.
Dec 11, 2010 | Samsung CXD2512 25 in. Combo
The LP on my Panasonic NV FJ-630 VCR doesnt show a
I know of four places that deal in Panasonic parts and they are all on-line!
Number one is Grandata, 2 is Willow Vale, 3 is CPC.
The fourth one I have just checked on and they have the upper cylinder unit in stock at £47.99 plus P&P!
And they are Curry's Partmaster.
You might want to try the others just in case they do it cheaper, but I find that Panasonic heads tend to be all around that sort of price.
May 08, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
EP to LP problem on VHS tape playback
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
Aug 09, 2017 | JVC HR-XVC33U DVD Player/VCR
Panasonic Super Drive video recorder
there are three creases in the head , have you made sure those are cleard?
Oct 21, 2008 | Zenith VCS442 VHS VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Open Questions:
Televison & Video Logo
271 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
