Replaced shifter tube
When replaced key will not turn starter switch tried it with a screwdriver with switch out and it still would not turn
  • 1596 Answers
SOURCE: 1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Posted on Jan 21, 2009
  • 78 Answers
SOURCE: ignition switch problem 2000 town and country
you need new ignation switch
Posted on Jan 10, 2010
Testimonial: "everything works after replacing the switch - it seems all it was a piece of plastic missing on the tip of the switch - thanks"
  • 564 Answers
SOURCE: replaced starter.1995 chev s10still wont start when key is turned
ck neutral safety switch or ignition switch,,
Posted on Feb 06, 2010
  • 553 Answers
SOURCE: Car won't start. its got a hot battery. Turn key,
If your car rolls over when you short the selonoid then the possibilities are limited.
The most likely is your neutral safety switch
the others are the ignition switch or damaged wiring.
Posted on Jun 11, 2010
tayjoejoe
  • 2194 Answers
SOURCE: dash dead ,turn key
It there is a problem with the dash, there is probably no power to the anti theft module in your ignition. The car is in anti theft mode due to not being able to read your key transponder. Basically if it cant read the key, it thinks its being stolen. Either fix the dash lights, or fully bypass the security. All the security info you need is on here including how to bypass it.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on May 03, 2011
Wires on starter but wont start will start with screwdriver whats wrong
The solenoid on a starter receives voltage when you turn your ignition switch to the start position that tells it to activate the starter. When you use the screwdriver to start the car, you are basically bypassing the solenoid on the starter. Since the car won't start when you turn the key, this means that either the solenoid is bad and the starter needs to be replaced, or the solenoid is not getting the voltage from your ignition switch that tells it to engage the starter. You might be able to eliminate the ignition switch as the problem if you get somebody to hold the key in the start position while you check to see if there is voltage at the starter solenoid. If you have voltage there, the starter solenoid is most likely bad, and the starter needs to be replaced.
Sep 26, 2014 | Cars & Trucks
20 amp fuse in ACC slot keeps blowing
ACC slot is the Accessories slot. Perhaps there is a short or overload condition in the vehicle with the cigarette lighter or an add on electronic device.
Try to connect the two posts of the solenoid to see if bypassing the key cylinder works the starter. If it does, then this points to the key switching problem for the starter to the solenoid.
Also, check the neutral/back up safety switch:
Neutral Start/Back-Up Light Switch REPLACEMENT & ADJUSTMENT
  1. Remove the console trim from the console.
  2. Disconnect the electrical connector from the switch.
  3. Remove the 2 attaching screws from the switch and remove the switch. Fig. 1: Neutral start/back-up light switch 85347017.gif
  4. To install a new switch:
    1. Place the switch onto the transmission control shifter and loosely install the attaching screws. Position the transmission control shifter assembly in the N notch in the detent plate.
    2. Assemble the switch to the transmission control shifter assembly by inserting the carrier tang into the hole in the shifter lever.
    3. Install the attaching screws and tighten.
    4. Move the transmission control shifter assembly out of N position. This will shear the switch internal plastic pin.
  5. To install the original switch:
    2. Rotate the switch on the shifter assembly to align the service adjustment hole with the carrier tang hole. Insert a 3⁄32 in. (2.38mm) diameter gauge pin to a depth of 9⁄16 in. (15mm) and tighten attaching screws.
    3. Remove the gauge pin.
  6. Connect the electrical connector to the switch.
  7. Install the console trim to the console.
Jul 04, 2010 | 1991 Chevrolet Camaro
Have power to lights, windows, etc. but when turning the key to start the vehicle, nothing happens...not even turning over.
try placing shifter in neutral and try to crank it, If it starts bad nuetral safety switch, If not check for power at starter when someone else turns to crank, If 12v is there replace starter
Jun 09, 2010 | 1989 Chrysler Fifth Avenue
How to replace 2004 sierra ignition
i have a sierra also... the wheel, shifter cowl, etc. has to come off to replace the ig. switch. good luck
ps... did you try putting the shifter in neutral and try to start it? there is a safety switch so that when it is in gear and running, so that the starter cannot be engaged..its best to have it checked out at a garage. bye...
Nov 09, 2009 | 2004 GMC Sierra 2500
1996 Saturn shifter stuck in park after replacing ignition
There is a switch between brake pedal and shifter that can fails. Also from ignition
Oct 22, 2009 | 1996 Saturn SC
How to adjust neutral safety switch
Usually neutral safety switches have asmall hole that a pin goes in, and then on install the shifter is placed in a position, like neutral, based on the switch positioning.
HOWEVER, I suspect that yours is installed, so I suggest plan B. FOOT ON BRAKE, turn key to on, move shifter into R.
Turn key to start, and slowly move shifter towards neutral.... Note exactly the shifter position when starter fires off, and release key, no start needed.
Then, do the same thing from Drive, move shifter towards N, with key in start position.
What you want is no start in either R or D, you knew that...And adjust neutral safety switch to "center" the starter actuation, preferably not until well into N, but that is not adjustable...
So, final is key to start position, test from Low, 2, d as you move shifter.... finally, you get start in N.
turn off.
Place in R, turn key to start and move towards Park, and you should have the starter fire off after out or R.
Hope this helps, that is what is involved.
Doc
Sep 21, 2009 | 1999 Toyota Camry
Have 1975 Merc 115 h.p. motor. won't turn over with key
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Jun 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Dec 23, 2008 | 1998 Buick LeSabre
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
