Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Westinghouse fridge freezer
I have a Westinghouse Virtuoso Fridge Freezer. The alarm continues to off at least 4 times in an hour. The fridge is NOT working my food is going off. Milk sour meat spoiled. The freezer is not working- nothing is frozen. HELP ME!!! I'm a single mother (struggling writer AND Aboriginal- so I'm a bit poor and need my fridge) I have two growing teenagers and can't afford to not have a fridge and freezer not working. I can't afford replacing off food because my EXPENSIVE recent Westinghouse virtuoso fridge freezer doesn't work! This is ridiculous! PLEASE HELP ME FIX THIS PROBLEM.
4 Suggested Answers
  • 4 Answers
SOURCE: westinghouse virtuoso fridge freezer on top has
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Posted on Oct 13, 2010
SOURCE: We have a Westinghouse Virtuoso
This is usually caused by a faulty, or going faulty, thermostat or the actual temperature sensor the thermistor itself, or sometimes both? The exact components must be tested to find out which one is actually faulty.
If you wish to DIY, then you must first obtain copy of a service manual, and follow the troubleshooting steps to isolate and hopefully resolve your issue, the SM also has disassembly instructions and also those all important parts numbers.
To obtain SM simply either Google the exact make and model plus the words service manual, or contact the manufacturer and obtain one that way.
However if DIY isn't the way you wish to go, then contact either a local or head office from Westinghouse, and ask them for a referral to an authorised service center, now when in face to face contact here, then ONLY ask first for a "Quote" as to what's wrong and how much the prospective repair costs will be, and go from there.
please find below a couple of websites that will help if you decide to go the DIY way? (To my professional m ind i feel using a professional is always best?)
http://www.appliancerepair.net/refr.htm
http://www.appliancediyrepairs.co.uk/
Posted on Aug 30, 2011
  • 884 Answers
SOURCE: I have a Westinghouse Virtuoso side by side fridge freezer. The circulation fan is not running but appears to be in working order.
Is there a switch just inside the door that is not making contact?
Posted on Jul 02, 2012
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
I have a westinghouse virtuoso fridge/freezer. The freezer alarm goes off every 1/2 hour and the freezer is cool inside it does not seem to be maintaining freezing temps. Is there anything i should try?
i have this fidge and suffer the same problem, i rang the company and it was only when i spoke to the manager he mentioned quietly to turn the fridge of for 5days with doors open to completely dry out the inside as its water gathering inside at the back and it worked the alarm stoppped, it was only cos i mentioned i couldnt afford hundres of $ for a repair guy, share the news it sounds commen in the model, ggod luck
Dec 17, 2010 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
21 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
