Question about Braun 8975 360 Complete Men's Shaver Electric Shaver
Trimmer does not work - Braun 8975 360 Complete Men's Shaver Electric Shaver
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Trimmer runs but the head wont turn
It may be that the drive shaft is broken, or not engaged to the engine. Make sure the trimmer attachment is locked all the way onto the shaft coming from the engine. If it still doesn't work, check by seeing if any of the other attachments work when you put them on. If they do, you know the drive shaft in the trimmer attachment is probably broken.
Aug 17, 2011 | Craftsman Convertible 25cc. Gas Line...
My Black&Deck 24" Hedge trimmer simply stop working. There is no action what so ever when I turn it on. Any suggestion? Do I need to locate and change the fuse? Thank you!
Check the black and white power wires to the motor. You will have to open the trimmer casing. I have 2, 18 inch B&D hedge trimmers and both of them stopped working due to wires coming loose at the motor. I re-soldered the wires to the motor and both trimmers work fine.
Jun 26, 2010 | Tanaka 30" Double Sided 24cc Hedge Trimmer
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
Where is the gas filter located on a troy bilt trimmer?
The fuel filter is inside the fuel tank. Replace the fuel filter. Do not clean it.
Apr 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Line continues to advance and wrap around axle
I used a file to sharpen the line cutter which controls the amount of line. After sharpening the small cutter on the trimmer, the length of the line is now under control and now my trimmer works just fine.
Sep 13, 2008 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Trimmer won't work
There's a post inside the trimmer that provides a location for counterforce when the teeth move; this is either weak, designed to break after time, or breaks simply because it's not designed to be opened/closed while running. It's relatively easy--if you're patient--to take the razor/trimmer apart and see the problem. A friend and I drilled an appropriately-sized hole through the back of the trimmer at the snapped-post location (which, if one looks at the outside casing of the trimmer is at the bottom of the indented arc), used a dremel tool to cut off an appropriately-sized metal rod, inserted it in the hole, then sealed it with hard (probably model) putty. Years later, it still works fine and--most importantly--I didn't have to buy a new razor.
Jul 11, 2008 | Norelco Reflex 5811 XL Electric Shaver
Braun 8975 360 Complete Men's Shaver Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
