Question about Frigidaire FAQG7001LW Dryer
Frigidaire faqg7001lwo diagnostic
Shuts down after 15 minutes with no error code
3 Suggested Answers
SOURCE: Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Posted on Feb 21, 2011
  • 107 Answers
SOURCE: f10 code and shuts off after 15 minutes of using wall oven
what is f10 code
Posted on Nov 22, 2013
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
Feb 15, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
Studio 15 screen blank
there is an inbuilt hardware diagnostic..
turn the computer off then hold Fn + power button to turn it back on.. it will automatically initiate PSA diagnostics.. will beep and ask you if u see the colour bar displayed.. if u see them respond accordingly or else.. let it run.. within 10 minutes you'll get an error if its hardware glitch.. call dell tech support at 1800-624-9896 and tell the error code.. they will replace the lcd kit by sending a tech at your place.
Dec 19, 2009 | Dell Studio 15 Laptop
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Diagnostic complete
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire FAQG7001LW Dryer Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
