Question about Technics Audio Players & Recorders
Technics sl b30 power cord
Need new power cord
SOURCE: Technics CD Changer SL-PD887
this is a standard plug you should be able to get from radio shack or other electronic stores. just take a picture of where the connection is on the unit with your mobile phone and show it to the sales person. cheers, mark
Posted on Sep 28, 2007
  • 104 Answers
SOURCE: new cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
Posted on Feb 11, 2009
  • 76 Answers
SOURCE: NEED NEW POWER CORD FOR WESTINGHOUSE COMPUTER
Usually monitor cables are standard, and are the same as your PC. You may want to try the one from your PC see if that works fine, then you know exactly what to get.
Posted on Sep 30, 2009
  • 460 Answers
SOURCE: The belt came off on my Technics Model SL-B30
there should be slots under the turntable mat big enough to get your fingers in. make sure the belt is around the table pulley set it on the middle spindle and then put the held part of the belt onto the motor spindle. then you have it. good luck..
Posted on Mar 09, 2010
westytech
  • 120 Answers
SOURCE: Westinghouse Model: LCM-17v2 SL DC Input
Hello Mike, you can order the adapter by calling the Westinghouse parts department at the toll free number 1800-701-0680 and selecting option 2 for parts. You can also send me a request for the part to westytech@westinghousedigital.com.
Posted on Sep 29, 2010
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
Replace Power Cord - Technics 1200 MK2
It's an ac cord. there is no positive and negative. the solid black side is "hot" and the ribbed or striped side is "neutral".
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Need power cord for technics sl-b20
Post a picture of the socket of the turntable. I think a cord from a Sony Playstation 1 may work if it looks like this.
Mar 30, 2013 | Audio Players & Recorders
I need a replacement power cord for my Technics SL-pd987 5 CD changer. Know where I can get one?
There's probably nothing special about the original power cord, so I'd go to Radio Shack or any common electrical supply store and get it for around $8
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
Sep 06, 2011 | Technics SL-PD987 5-Disc CD Changer
Cannot adjust speed on a vintage Technics SL-B30 Turntable
First has anybody tried to repair it before you got it Gerry? I ask this because someone could have fitted the wrong type motor!
If nobody has done anything to it, I would take a look at that servo control board. Is there any IC's on it, if there is look at them with suspicion.
Aug 25, 2009 | Technics SL-1210 Turntable
I have a SL-B30 that when turned on won't start up.
if your model does not say "direct drive" on the front then it sounds like your belt came off. this video will show you how to put it back on
http://www.archive.org/details/Turntable_Belt_Installation
Feb 15, 2009 | Technics SL-1210 Turntable
Power cord for Techniques SL-PD9 CD Player
Fairly common cable - I have several for various chargers for cameras, camcorders and laptops. You can get them at Radio Shack
Feb 01, 2009 | Technics SL-PD9 5-Disc CD Changer
55 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
