Question about Husqvarna 22 Hp 46" Deck Yard Tractor
The mower deck doesnt stay kicked in
It keeps kickin in and out but never stays fully running
  • 486 Answers
1) check condition of deck drive belt
2) check condition of belt tensioner system located on top of the deck.
tensioner system pivots and also applies brakes on spindles
being worn, it does not give full travel to tension the belt
3) make sure engine mount bolts are tight
4) engine 'Stack Pulley' groove can be worn
5) check idler pulley bearings
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 04, 2009
Why won't my rider move and keep running?
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Jul 21, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
Mower won't stay run
If your machine only runs on choke then you need your carb cleaned or replaced
Aug 04, 2014 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Polan 14.5 rifding mower won't stay running when clutch released
Either a problem with the seat switch, or just make sure the block connecter that gose to the switch is fully pushed into the switch if its even slightly off it will stop the engine.
Jun 17, 2012 | Poulan Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Mower doesnt charge battery. does stay running after charge from charger what goes bad to have this happen
Check and clean all of your connections at your solenoid back to "shiney and bright". That sounds like the problem.
Best regards, --W/D--
Aug 21, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Mower shuts off while mowing grass
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower wont stay running
take hose off and take to local hardware store.probly got something that would work
..freaken sears..')
Jun 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deck belt
Look at the Idler pully on the deck ther should be a Spring that keeps tension on the belt if it does not have that feature on that deck then there is a stay pin missing or the belt has just gotten to big (streached)
Apr 08, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna 22 Hp 46" Deck Yard Tractor Logo
138 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
