Question about Blaupunkt Car Audio & Video
Surround sound all ok cab speakers not working
Cab speakers not working
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
farr64
  • 121 Answers
SOURCE: surround sound not working
sorry but start with the obvious..the surround speakers usually are a looped curcuit using one single live split .so check each speaker works the cable is ok .if all checks out ok go for the selector switch if its a push switch press it repeatedly .if all this fails tap around the unit there might be a dry joint.good luck .farr64
Posted on Apr 29, 2009
renx
  • 71 Answers
SOURCE: Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
Posted on May 02, 2009
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
SOURCE: Surround sound speakers won't work
I have the same problem. This works for some people, it didnt work for me. 1. Remove any discs 2. turn the unit off and unplug 3. wait about 20 secs and replug the power cord. 4. turn unit back on .Press dvd button on the remote to take unit to the dvd mode. 5.Using remote enter 76419. The display should say GOODBYE and go off. Press the power botton again to turn on and good luck
Posted on Jun 07, 2009
No sound at all from HTQ20 surround sound. Any advice welcomed
Does your speaker indications come on for surround command on the HTQ20? Check the speaker connections. If all OK are your speakers connected in the right polarity? If that is also OK check your speakers with another device for functioning. If that is also OK there should be something wrong with your surround output.
Nov 19, 2017 | Audio Players & Recorders
Awia speaker ok for home thaeter
Just about any speaker will work for home theater. As long as it makes sound.
Of course, you will need some type of surround sound processor (like a surround receiver) and other speakers to connect to the front left, center, front right and surround connections.
Some speakers will work better than others.
I will not get into any specifics because there is WAAAAY to much information to get into. Do a little research on home theater systems and how to design, hook up etc.
May 02, 2014 | Aiwa Audio Players & Recorders
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Only two speakers will work on my dell dimensions 2400. Trying to use the Kinyo ta-927 surround speakers
HAVE YOU GONE TO THE CONTROL PANEL AND SET IT UP IN SOUNDS AND AUDIO THEN GO TO SPEAKERS ON THE SOUND TAB AND GO TO ADVANCED AND MAKE SURE IT'S SET UP FOR SURROUND SOUND .....OK
Jul 09, 2009 | Kinyo TA-927 Computer Speakers
Surround sound not working
Apr 29, 2009 | RCA RS2600 CD Shelf System
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Car Audio & Video Logo
26 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
