Question about Oreck Touch Bagless Upright Vacuum, BU10010
Not much suction burn smell
Removed brush to clean
What is causing the beater bar brush to spin extremely fast?
HI, it's Jim from Crucial Vacuum!
First thing is to be sure to unplug your vacuum. Once you begin smelling a burning smell it's essential to stop vacuuming immediately.
One of two things may be happing here:
1) Your brush roll may need replacing. It's possible that the sides where it attaches to the vacuum have been worn down with age. The bristles falling off is a clear indicator that it's time to replace the brush roll. Also, look for debris, or hair that's wrapped around the brush. Remove all of this with either a razor, or a scissor.
2) Check your vacuums belt. Is it wrapped around the brush roll at all, or is too loose? If so, this means there's no tension around your brush roll and it could be causing your vacuum to overwork the motor and overheat, hence the smell.
Clean this area out and then replace the brush roll and belt. You should be seeing a noticeable difference in both your vacuums suction, and a lack in the burning smell.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 30, 2015 | Vacuums
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
No suction on my Hoover Dimension
If you smell something burning unplug until problem is found and fixed, suspect if no suction hose is blocked and if brush wheel it or the belt may be causing the smell, a bad or failing motor is less likely but possible.
Nov 02, 2012 | Vacuums
Brushes not rotating on kirby vacuum
Change the belt, they stretch after while. If it made a burnt rubber smell or it's > 1 year old this is probably your problem.
Here's what you need:
http://www.vacuummedic.com/product.php?id=279
Good Luck!
Vac Dr.
Oct 15, 2012 | Kirby G4 Bagged Upright Vacuum
I turn on my eureka and i seems theres no suction and it smells like burn
The burning smell is most likely from the drive belt that has seized up for some reason.First and least expensive step to take would be to remove the brush on the bottom of the unit. Clean it thoroughly and remove all debris, especially on the two end pieces. The brush rotates around the two end pieces, so they must be able to be turned by hand. Spray a little WD40 on them if you need to free them up a bit, turn by hand so they are free to move and then replace. If the belt looks work or stretched, now would be a good time to replace it.
Sep 16, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Drive and brushes stopped
Look for a missing belt that may have burned off or broken. Was there a burning smell at some point before the roller quit turning? If so, the belt must be replaced. I would also look at the ends of the roller to see if there is any string, hair, etc. that might be binding the roller that needs to be removed.
Jan 24, 2009 | Hoover U8125-900 Savvy Bagged Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Oreck Touch Bagless Upright Vacuum, BU10010 Logo
52 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
