Question about Tractor Tunes Kubota Rtv 500 Pioneer Radio Stereo Console Rmt-dlr
My radio wont come on and my dome light just flashes
Radio wont play
No power to sterio, over head dome lights, or Dash lights.
I think there should be another fuse for the dash lights and radio and dome (or interior or courtesy it may be designated). Recheck all of those fuses under the dash, I believe one has blown out. This is when a wiring diagram comes in handy-you can see the fuse lay-out, and what circuits each one serves.
Aug 29, 2013 | 1996 Geo Tracker 2 Door
2002 Saturn dashlights flashing, wont start. No dome light, radio, locks dont work.
Have the battery tested, it sounds like it is defective or the battery cables are corroded.
Oct 02, 2012 | 2002 Saturn L-Series
Radio wont play, clock wont come on and my dome light wont come on. What might the problem be?
Check your fuses.There are 2 fuses for the radio.One for the radio power and lighting and one for the clock for the radio.You did not state what model Buick you have so I can`t tell you what fuse box to look at for the fuses.Always state year ,make,engine,and model of vehicle if you want to get your questions quicker.It makes it easier for us to look up.Other it could be a guessing game and you would not get a good answer.Also you should always rate the answers.That`s your way of saying thank you to us.Hope this helps.Let me know the info and I`ll be glad to help you out more if needed.Good luck.
Mar 04, 2011 | Buick Century Cars & Trucks
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Jan 30, 2010 | 1997 Acura RL
Radio wont hol memory, dome light wont work when key switch off, and All lock wont unlock doors unless key in on.
Probably a fuse. You radio keeps it's memory using a constant power wire which is probably interlinked with the dome light, door locks, etc. Check fuses under the dash as well as under the hood for any blown fuses. Look for fuses labeled with your listed problems of things that don't work.
Jul 07, 2009 | 2002 Honda Civic
When I shut off the ignition the radio and dome light stayed on
I have the same truck. The thing is designed so that the radio and dome light and even the windows will operate for a time which should expire immediately when you open the door. Try turning on the radio with engine running and then turn off the engine and just sit there and the radio should still play. Try the power windows - they too should go up and down. Finally open the drivers door and that should immediately kill the radio, windows and dome light. If it does not - you will need to report that problem to your dealer since the problem is in that timer feature which is part of the vehicles "brain". Sorry I can't be more helpful.
Dec 19, 2008 | 2003 Ford F250 Super Duty Crew Cab
Short ?
the wiring for the dome light, door ajar and radio is most likely crossed with the brake light wires causeing it to turn off power or on when pressing the brakes giving electricity to the lights and then it could be cutting off the power to the radio
Nov 10, 2008 | 1999 Ford Explorer
Tractor Tunes Kubota Rtv 500 Pioneer Radio Stereo Console Rmt-dlr Logo
27 people viewed this question
Top Tractor Tunes Computers & Internet Experts
David Payne
David Payne
Are you a Tractor Tunes Computer and Internet Expert? Answer questions, earn points and help others
