Question about Bosch MUM6612 Universal Series Mixer
Mum 6612 Mix
I want to know the ages of Bosch Mixers mum 6610 and mum 6622. I cannot find a list of manufacture dates on these two models. I want to know which one is the newest between the two and if there is anything...
Well, the advantage of Bosch Mixer mum 6610 is best for large families because of its motor speed which is really high while bosch mixer 6622 is actually amazing, with a dough hook, it has softer bread, and basically idealist for any family. These machines are made to last so the best solution for you would be to contact your supplier so that he can give you specifics but hardly are given, all the same, the bosch 6622 is fantastic in comparison.
Jun 14, 2014 | Food Mixers
Dough hook & beaters slipping
you can generally find a local repair shop that specializes in resturant/bakery equipment/small aplliance. they will have the parts you need as well.. good luck please rate this
Sep 03, 2008 | Bosch MUM4420UC Compact Series Stand Mixer
Will not mix
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
Apr 06, 2014 | Sunbeam 2347 MixMaster Heritage Series...
Chef tony parts for t-mix
I have lost the white plastic spindle from the stick blender of the chef Tony T Mix can a replacement be bought
Feb 25, 2013 | Food Mixers
I did not receive a manual with my Mix Master model# 2349
If you go to www.apwagner.com you will get the story on Sunbeam and perhaps you may be able to get a manual. Please rate this answer,thanks.
Apr 11, 2009 | Sunbeam Heritage 2346 Stand Mixer
Doesn't mix in the bottom of mixer
Using the tilt release switch, tilt the head all the way back. This will expose a large screw inside the hinge which you can turn both ways to either get the beater closer or further away from the bottom of the bowl - can't remember which way is which, though. (I had the exact opposite problem: the dough hook was grating on the bottom of the bowl.)
Hope this helps. Have a happy Christmas
Dec 21, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Broken mix master
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Sep 11, 2008 | Food Mixers
Bosch MUM6612 Universal Series Mixer Logo
29 people viewed this question
Top Bosch Food Mixers Experts
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
