Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Losing date and time when removing batterey on Kadak Z812IS
Doesn't show and thing about it in manual. My cheep other digi holds the info
Take the camera to a repair shop and tell the tech man to replace the "super capacitor."
Problem will be fixed
Posted on Dec 19, 2009
DIGI SM 90 Type 2 not able to print best before date please help
need more info:
which printer is installed ?
what is best before date?
Jan 26, 2014 | Computers & Internet
My Kodak easyshare z812is will not let me take picters it will not go off the fave pics no matter what I do help
According to the manual, there not much you can do.
Switch the camera of and on. Please remove the batteries for a little while. You should take care the camera is not in Favorite pictures position. Adjust time and date if the camera asks you to do so.
If the camera is switched of, batteries are out and you did chose an other setting like smart scene, and after you replaced or put in good batteries. After switching on the camera should not be in favorite pictures. If it is still there the camera has a lose contact. or perhaps a contact is coroded. If turning around the dail does not solve the problem, after you tried everything above. I think you should visit a repair store, or save that money and buy a new camera.
Oct 31, 2013 | Cameras
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
If I remove the battery on my mother board will I lose my settings??
The CMOS battery really doesn't hold too much. It mostly saves things like date and time, but since the advent of the internet, most of the CMOS settings are re-calibrated every time you connect to the internet(most of us are connected at all times now). Change it at will. You probably won't notice any change at all.
Nov 10, 2012 | HP Computers & Internet
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
When i ON my digi camera its asking date n time every time???
You may continue using the camera without replacing the CMOS battery. You'll have to put up with the opening screen, and the photos you take won't have the proper date/time information if you don't set the clock, but otherwise the camera will operate fine.
May 21, 2012 | Sony DSC-W210 Digital Camera
Can not set date on kadak easyshare c330
The camera should be able to have its date and time set through the menu and it should hold the date if you switch batteries. If it doesn't then the internal battery may have to be changed by a kodak service center.
The camera screen displays "Date/Time have been reset." What should I do?
This message appears if:
  • this is the first time that you have turned on your camera.
  • the battery has been removed for an extended period of time.
  • the battery is exhausted.
To set the date and time:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date & Time feature.
    3. Set the date and time.
  3. When you are finished, press the OK button.
For more information, see your camera user's guide for your camera
Dec 18, 2010 | Kodak EasyShare C330 Digital Camera
Battery not holding a charge. Intermitent power at ignition switch.
When a batterey no longer holds a charge, it is time for a new battery. What is the date on yours? If it is older then 48 months ... start looking.
Thanks for your interest in FixYa.com
Aug 02, 2010 | 1995 Volkswagen Passat
Canon DH V
For date:
1 Hit the date/time key above the cost key until the date shows
2 Hold down the M+ key until the first digit flashes
3 Enter date info with the numeric keys
4 Hit the M+ key to save
Time:
1 Hit the date/time key above cost key until time shows
3 Enter time info with the numeric keys
Dec 13, 2008 | Canon P23-DHV Calculator
Finepix 1400 info needed
No battery back-up. There is a capacitor that stores a bit of charge. This allows you to replace the batteries and still keep the date/time setting. Leaving the camera without batteries for 10 minutes will completely drain the capacitors. This will cause the date/time to reset.
Sep 04, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
197 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
