Question about Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner
Can not get engine to start
New out of the box
Would a bad CDI unit cause the engine to die when shifted into reverse and not provide spark when started with the start switch?
I suspect you have a wire crossed and it might not be your fault. You might want to research the pin/wire locations. can't help you with the reverse part because I have no idea what it is you're working on
Oct 12, 2014 | Garden
Has spark, new gas, new fly-whl key, has compression-95 still no start.
Could be the igniter box. It tells the engine to start. Rolls over like it wants to start but won't. Also look to see that nothing is unplugged to it or the fuel pump/carburetor solenoid could be bad as well. Mice love chewing on all of the above. Mine was the igniter box $$. Plugged new one in, started right up, everything was good to go. Hope this helps.
Sep 29, 2014 | Garden
Will not start
go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Feb 27, 2018 | Jeep Compass Cars & Trucks
1990 montero won't start
Go to any service center.They can fix it.
Nov 29, 2013 | Procom Programmable Cdi/ecu Ignition Rev...
Engine does not start when warm
here is a problem... No service center to fix this box store lawn mower... If it is brand new I would take it back and get a new one because I would be willing to guess you have either a valve adjustment issue or a bad ignition coil which shouldn't be an issue with a brand new mower.
Nov 12, 2013 | Mtd 19 In. 173 CC OHV 3-In-1
My 93 rm 250 started smoking heavy and loss power and is shooting oil in my air filter box
if a four cycle engine I would say either you have a lot of work ahead or engine replacement. The only way to find out is boroscope the cylinder to see for piston damage. or total teardown for rod damage. I think you blew it up.
Aug 02, 2012 | Suzuki Cars & Trucks
Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner Logo
22 people viewed this question
Top Maxtra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Maxtra Garden Expert? Answer questions, earn points and help others
