Question about Nordic Track NordicTrack C2500 Treadmill
I need to reset the fitness journal
Need to clear stored information in the fitness journal
Royal cash register Alpha 1000ml electronic journal cleared
Royal don't tend to give out this info. and this model is rare to find. You will need the code for Journal clearing. I've found that it varies too much between registers to guess it by other ones. For the royal machines, I usually just send customers to buy the manual from the supplier. There is also a PDF manual on the net if you need one quickly:
https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Sorry I can't help further with this model
May 09, 2015 | Royal Alpha 1000ML Cash Register
How to print electric journal for sams4 ER-265
On the 265 you will need to enable this feature first in the program flag setup. Once enabled, print journal by turning key to X and pressing 300 CASH. Then to clear the electronic journal, turn key to Z and press 399 CASH
Mar 15, 2014 | Sharp XE-A402 Electronic Cash Register
Casio pcr-t2100 I reset the register using the journal feed and pgm to off. I don't know how long it takes or if i need to do someting else to allow me to program it again. Currently i am in init mode...
If you are trying to clear the programming, that is the wrong way for this model. Take one battery out, turn key to PGM mode. Unplug the power for about 30 minutes then plug back in. Fit battery back in. Start reprogramming. If you need a manual, one of the users has one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2100_users_and_programming_manual.html
Jun 09, 2013 | Computers & Internet
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
How do you clear the e journal
1. Press [Mode]
2. Press [X/Z report]
3. Press [Daily Z]
4. Press [E-Journal]
5. Press [Reset Only]
6. Pres [Yes] to reset it.
Sep 30, 2009 | Casio QT 6000 Point of Sale Terminal
Sent Journal print out - date specific
Not possible.
Most fax machines only store the last 50 transactions.
Dec 15, 2008 | Office Equipment & Supplies
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Storing Outbound Faxes not sending.
if you print a tx journal does it have an error on those you tried to send
Mar 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Nordic Track NordicTrack C2500 Treadmill Logo
22 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
