Question about AO Smith Pool & Spa
How do i change the brushes
Is it even possible to change the brushes in an a.o. smith pool pump motor
  • 372 Answers
These motors are "brushless". If the motor has failed it usually is because of a failure in the windings. If it it making a loud noise, that is the bearings going out.
Posted on May 16, 2014
  • 10865 Answers
SOURCE: Which wire goes to which post ? Intermatic T104R
The two wires are interchangeable.
Posted on May 06, 2009
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
  • 64 Answers
SOURCE: Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
Posted on May 29, 2010
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Can yoy spin a hayward 1.5 hp motor with a screwdriver
by Osko Pool n Spa
Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
Find more information at:
http://www.oskopoolnspa.com
Aug 27, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Replaced the seal and impellar, now pump is getting hot and turning off? any suggestions
SOUNDS LIKE YOU GOT THE WRONG IMPELLER, THE ONE YOU GOT IS FOR A BIGGER MOTOR.. THESE IMPELLERS CAN BE A PAIN TO ID, OR EVEN FIND .. TRY THE IMPELLER FOR A 1HP. I BET IT WILL WORK JUST FINE .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FL ..
Feb 27, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Need ao smith replacement motor for anthony pool pump not sure what motor fits that pump
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Aug 16, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pool & Spa Logo
61 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
