Question about Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
Hi,what the problem is the machine come out error code SC121.....please help me to soft this problem?Thanks.
  • 355 Answers
Sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Posted on Jun 15, 2009
    New Friend:
  • 10 Answers
Sc-121 in ricoh 1035 and 3502 is for Scanner home position error,
reason of this error :
Scanner motor defective OR Scanner HP sensor defective OR Scanner wire, timing belt, pulley, OR
carriage defective check them
Posted on Jul 13, 2014
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
SC121
These are the possible causes of your "scanner error" (SC121). You'll need a tech to solve this:
* SIB or scanner motor drive board
defective
* Scanner motor defective
* Harness between SIB and scanner
drive motor disconnected
drive motor power source
disconnected
* Scanner HP sensor defective
* Harness between SIB and scanner HP
sensor disconnected
* Scanner wire, timing belt, pulley, or
carriage defective
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
1,026 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
