Question about Yamaha HTR-5990 Receiver
No sound from Yamaha HTR-5990
About a year ago I set up a new home run media cabinet. This receiver was to be the center of my whole home audio. When I got my cable box, I made my HDMI connections and hooked up a pair of speakers (rear).  But I could never get any sound out of the thing.  The video carried through to my TV, but no sound from the speakers, not even the TV speakers.  Do I have to have all the speakers hooked up for this to work?  Is it possible the electronics are toast?  My simple 'bench' test was a failure and discouraging.
  • 979 Answers
Re: No sound from Yamaha HTR-5990
You must be sure that you also have "audio" cables connected to the receiver to make this all work. As far as the TV is concerned, the same applies....accordianman
Posted on Oct 31, 2007
0 characters
3 Points
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Receiver the HDMI inputs only one works is the other switchable?
according to yamaha website you have 2 hdmi inputs, and one hdmi out on that unit
Mar 07, 2013 | Yamaha HTR-5990 Receiver
No compressed audio on hdmi If I send compressed Dolby Digital to the HTR-5990 via HDMI, the indicator shows "PCM" and no audio is heard.
You probably need to take that issue up with the setup of the unnamed device originating the signal.
Mar 23, 2010 | Yamaha HTR-5990 Receiver
Audio keeps cutting out intermitenly on my Yamaha htr-5990 this will happen no matter what input is being used
Is it going into protect mode???
If so, check your speaker connections. Make sure there are no loose copper wires hanging out, and that your splices are clean at both the receiver and the speaker.
Feb 12, 2010 | Yamaha HTR-5990 Receiver
What model of remote comes with this yamaha htr 5990
The RVA350 comes with this model according to the manual.
Hope this helps
Oct 07, 2009 | Yamaha HTR-5990 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Did you ever get this resolved?  I have a similar problem, my video feed seems to work but I have never been able to get any sound from my speakers using this component.  I'm not sure what YPAO setup is but I just read a suggestion to reset the receiver to factory settings in the event something is programmed that causes the problem.
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
No Video when using component Video/Audio cables
if you are useing component cable on you dvd, and you dont get video ! Check your setting on the dvd menu. change your video setting from composite, to component.
Nov 30, 2006 | Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Receiver Logo
467 people viewed this question
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
