Question about Hardware & Accessories
I need diehl 884.1k User guide
It is quite easy to find 884 guide but this one is different. here you can see a picture http://i.ebayimg.com/t/DIEHL-Typ-884-1K-230-240v-50-60-Hz-Thermostat-timer-new-used-1-week-Ferroli-/00/s/NTgwWDY0Mw==/z/aLMAAOxydlFSoxz6/$_35.JPG
3 Suggested Answers
SOURCE: Need to replace a Diehl Typ 880, T85 120V 60Hz
The Type 880 is the exact replacement. Still available at most pool supply outlets.
Posted on Feb 10, 2011
SOURCE: manual for diehl multi-timer typ 181-5
Timer number does not match Diehl timer numbers
1) Diehl timers and manuals appear on following links:
http://www.borggeneral.com/
http://www.borggeneral.com/diehl-control-timers.html
2) Add a comment with in-focus photo of timer posted on flicker for possible identification and more help.
Posted on Jul 19, 2011
How can i bypass a diehl 883 timer
Add a switch between the 3 and 5 terminals
http://waterheatertimer.org/images/Deihl-880-wire-350.jpg
Add 2 different switches between 3 and 5 -and- 3 and 4 terminals:
http://waterheatertimer.org/images/Deihl-880-wire-DPST-600.jpg
Override timer with countdown timer:
http://waterheatertimer.org/Override-timer-with-countdown-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 13, 2015 | Diehl Hardware & Accessories
I need user guide for Diehl 884.1k timer
attach close-up photo or video of your product:
http://waterheatertimer.org/How-to-set-Vokera-mechanical-timer.html#PB
Of course fixya will degrade your photo so we can't see it anyway, but you could also describe timer in detail for best result.
gene h
Mar 30, 2014 | Diehl 1 Timer Module,1 Pole, Model 2a517...
WHERE TO BUY IN AUSTRALIA
Diehl timers at Amazon:
http://www.amazon.com/gp/search/ref=as_li_qf_sp_sr_tl?ie=UTF8&camp=1789&creative=9325&index=aps&keywords=Diehl%20timers&linkCode=ur2&tag=waterheaterti-20
mmmmmmmmmmmmm
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
Or replace with Intermatic FM1 series timer module:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
WW Grainger sells diehl, so does Borg
Add a comment and describe timer in detail in event that question was truncated by fixya.
May 13, 2013 | Diehl TIME CLOCK- 240V 24HR SPST TA4065
Manual for diehl multi-timer typ 181-5
Jul 19, 2011 | Hardware & Accessories
Want maunual of aspire 5742 to printout
Go here.........http://laptoprepairmanual.blogspot.com/2011/05/toshiba-satellite-c660-manual-user.html..........and the manual can be downloaded
Jun 24, 2011 | Acer Aspire 5742Z-4200 Notebook
I have an old 40 gb ps3 console and it never used to overheat but lately after the firmware upgrade its seems to be overheating quite abit
Overheating in PS3 consoles due to excess use can create technical fault. This can be repair with the help of Easy and Complete PS3 Repair Guide.
The PS3 Repair Manual is user friendly and easy to understand. You can fix all major problems of PS3 with this manual and the diagrams and easy instructions written in it. Apart from that, it comes in CHEAPEST price and would help you save money that you would spend while taking to different repair shops.
Jun 20, 2011 | Sony Playstation 3 (PS3) Console
Need wiring diagram SPST power to timer timer to light . two screws marked timer 1 nc 1no 1 com
Here are two possible solutions, since timers are made different ways:
1) Diehl timer has 5 terminals
Drawing below shows wiring for Diehl SPST:
2) Your timer might also be wired as follows:
Two screws marked 'timer' are for 120Volt Hot and Neutral that power the clock motor (in drawing above, these are terminals 1 and 2).
Another Hot wire connects to COM. (in drawing above this hot wire shown connecting to terminal 3)
Load wire connects to terminal NO (in drawing above this wire shown connecting to terminal 4)
3) NO is Normally-Open turns ON when tier turns ON
NC is Normally-closed is ON all the time, EXCEPT when timer turns ON. So NC terminal turns OFF when timer turns ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 31, 2010 | Diehl TA-4150 24 Hour Electromechanical...
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
Hardware & Accessories Logo
533 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
