Question about Aquabot Turbo T2 In - Ground Pool Cleaner
Cleans only a bout 50% of my pool and doesnot clean walls. My pool shape is a foot print.
    Problem Solver:
  • 15 Answers
Both of these problems could be the installed floats. There are 3 of them normally installed, and they do have a finite service life. Old ones often absorb water, making the unit not cover the full pool area or climb walls, S. Christian dansker01@msn.com
Posted on Aug 22, 2009
Baracuda only cleans side of pool how to clean entire pool surface
most of the time that auto pool cleaners "Head for the side" its because customer has set speed too high , need to slow down , consult your owners manual for specfic methods on how to do this , in this case slowest wins the race!!!
Sep 27, 2014 | Zodiac Baracuda G3 Automatic In Ground...
Printer Brother DCP-6690cw unable to print 50, sometimes unable to clean 50. please help
A 50 error code indicates a problem with the "maintenance unit".
This unit controls and cleans the printhead and ink delivery system. You will need a technician to figure out if this is the problem or some other component has failed.
Sep 03, 2013 | Brother Office Equipment & Supplies
What's a footprint tarp?
It is a tarp that fits exactly under the footprint of your tent, but is an inch or two smaller. If you have a 10' x 10' tent, your tarp would be about 9'10" x 9'10". If you have a triangle-shaped tent, your tarp would be triangle-shaped.
It is smaller than the tent so rain (etc) does not dribble down the tent wall, land on the tarp, and pool under the tent.
Jul 30, 2012 | Camping, Backpacking & Hiking
My Nitro Wall climber only cleans a small area back and forth for the entire 3 hour cycle. It litterally rocks back and forth in 1-2 second motion spurts. The drive wheel in the back seems to be working,...
The pump motor is responsible for the programming of the unit and it is failing. You will need a new pump motor installed to correct the issue. For information about sending the unit in for repair you can try our site at www.arrowpools.net or the manufacturer at www.smartpool.com.
John
Aug 19, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Our aquabug cleans in one area of the pool only.
Make sure that you are getting proper water flow. With these automatic pool cleaners, it is often an issue with the return line not getting to proper water pressure to the cleaner. Also, check for any lose hoses, cracks, or worn shoes that would prevent proper movement.
Jul 18, 2010 | Hayward Aquabug Above Ground Pool Cleaner...
What is the difference between the red light and green light?
my wall climber only wants to climb the walls. it won't run in a straight line. it only cleans a small part of our pool.
Jul 06, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Kreepy cleans the deep end great. It cleans the walls and bottom but will not venture up the slant to the shallow end
There are several things that could cause these automatic pool cleaners to have this problem. First, check the return line water flor and redirect it if necessary. Also, make sure that the hose is long enough to cover the entire pool without difficulty. Also, check the hose balance to make sure that it is correct.
Jun 22, 2010 | Universal Kreepy Krauly In-Ground Pool...
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Aquabot Turbo T2 In - Ground Pool Cleaner Logo
327 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
