Question about Uniden Radio Communications
Battery drain on uniden bc2500xlt when turned off
Battery drains even when scanner is off this is a known problen in 1st released models
SOURCE: Batteries drains quickly
I had something similar, it kept saying "battery low" after putting in new batteries. Try the Clear method; Take out one battery, hold the Clear button, while holding it insert the battery again and press on, and release. Now press clear again, turn it off and turn it back on again. If that doesn't help... well it must be something else... sorry :S
Posted on May 31, 2007
emissionwiz
  • 75822 Answers
SOURCE: Occasional Battery Drain
The battery was not making a good connection would be my best guess, clean them both again to make sure.
Posted on Sep 22, 2008
motorhead427
  • 24 Answers
SOURCE: Brake and Parking lights won't turn off, even in "OFF" position - Drains battery
Get under the dash ad look at your brake pedal lever. You will see a stop light switch that screww into a bracket with a 'button' sticking out of it. if pulling up on the brake pedal (even slightly) solves your problem, then the switch needs adjusting closer to the brake lever. If adjusting does not stop problem then replacement of brake light switch may be required.
Posted on May 30, 2009
  • 86 Answers
SOURCE: battery contstantly drains on 1989 Honda Goldwing Trike 1500
did you start it and put a volt meter on it to verify your getting approx 14 volts to the battery?
Posted on May 31, 2009
  • 4 Answers
SOURCE: does not turn off and drains the battery
Check your remote wire, AKA "REM".
If you other amplifier turns off properly when the stereo turns off. Try to find where that amp's REMote wire goes. (It will be a verry thin cable (compared to your 12v rail for power).
If all else fails, you can always connect your REMote wire to a 12v source (ANY 12v source that turns off with the vehicle) Such as a cigarette lighter socket, or any other 12v source that turns on and off with the car.
Tx,
JeremyM
Posted on Jul 29, 2009
Uniden ubc92xlt
Remove the battery for a hour. Put the battery back in. Press down at the same time and hold the #2 and #9 key when you switch it on - that will do a factory reset on almost all Uniden scanners. Then release, push manual, program, enter frequency of the local weather station and you should hear it.
May 05, 2014 | Uniden Radio Communications
How do I reset a BC2500XLT
TO RESET YOUR SCANNER BC-2500XLT & OTHER UNIDEN SCANNER!
MAKE SURE YOUR SCANNER IS TURNED OFF! THEN HOLD DOWN BUTTON #2 & #9 & MANUAL BUTTON ALL @ SAMETIME THEN TURN ON POWER !!! NOW THE MEMORY IS CLEARED & READY TO REPROGRAM YOUR SCANNER!!!!!
Feb 23, 2013 | Uniden Radio Communications
Battery drains on start up - only on the 1st start of the day after that its sweet - but I need to jumpstart it on the 1st start of the day even if battery has good charge
What you are discribing is a battery with a dead cell that is worn out. Have Autozone test it and see if I am right. The testing is free.
Jun 19, 2012 | Ford Fairmont Cars & Trucks
Battery drains even if its turned off
Welcome to fixya
Please reply back with the brand, model and operating system of your computer and I can give you steps on how to resolve the issue
Hope to hear from you
Jul 19, 2011 | Computers & Internet
Have a bc2500xlt that battery pack is gone. were do i buy one?
The battery pack (BP2500) and power supply/charger (AD70U) for your scanner have both been discontinued by Uniden, but I did locate a battery pack on eBay. You can check it out here:
http://cgi.ebay.com/BP2500-Battery-Pack-Uniden-BC2500XLT-BC3000XLT-Scanner-/180531979744?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2a088b65e0
Considering the fact that your scanner is about 15 years old, and the price of the battery pack is $56.99, you would probably be better off donating the scanner to a museum and buying a new one.
My apologies for being the bearer of bad news.
Bill B.
Aug 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
I have a uniden bear cat scanner
That scanner dates back to 1987, so chances are that the battery pack is well beyond charging. I found a new battery pack here:
http://cgi.ebay.com/WALKIE-TALKIE-BATTERY-UNIDEN-RADIO-BC100XLT-BC200XLT-/310272646372?pt=LH_DefaultDomain_0&hash=item483db0dce4
but it will set you back more than $90. Another option is to open/dismantle the battery back and use a battery insert. You can purchase one for $12.95 here: http://www.batterybarn.com/jbbt049.htm
The original battery is rated at 7.2VDC, but the charging circuit is set up for 12VDC at 500mA, so stay with your 12 volt charger.
Bill B.
Listening in since the 60's
Jul 26, 2010 | Uniden BC60XLT Handheld Scanner
My scanner won't turn on
Make sure you have fresh new batteries,and installed correct,check the battery connections,sometimes thes have been known to corrode from leaking,or check that you have the switch where the battery are located in the proper setting.....hope this helps....
Mar 14, 2010 | Uniden BC72XLT Handheld Scanner
I have a 2000 Dodge Durango 5.9l V8 SLT which I have had since new. Recently My battery drained and ended up replacing the battery, and the same problen occured again so I replaced the battery again. I...
Have you checked the automatic tensioner? It sounds like your belt may be slipping, causing the alternator to not charge the battery as quickly as it needs to, which puts a lot of strain on a battery.
I would have the automatic tensioner checked and replaced, and install a new belt.
Jan 12, 2010 | 2000 Dodge Durango
Starting problens with 2000 S-40 Volvo
you have a phatom drain on your battery thats something draining your battery when your car is turned off
Oct 07, 2009 | 2001 Volvo S40
May 30, 2007 | Texas Instruments TI-83 Plus Calculator
Radio Communications Logo
27 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
