Question about Flotec Plumbing
Sump pump open
Oil drained
djicenova
  • 319 Answers
SOURCE: oil sump drain plug
most likely a 17MM
Posted on Feb 27, 2009
  • 2692 Answers
SOURCE: sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Posted on Mar 12, 2009
SOURCE: sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Posted on Nov 21, 2009
agent91
  • 2100 Answers
SOURCE: drain sump oil
What kind of oil did they put in? The drain is on the lowest part of the engine, a small plug either in the block or at the end of a pipe, just find a container to fit under there and pull the plug, then fill it back up with the fresh oil. Don't forget the plug!
Posted on Feb 18, 2010
john224
  • 1378 Answers
SOURCE: My Zoeller M53 Sump Pump
If your seal or gasket failed and water penetrated into the motor cabinet how certain are you that whatever you have done has actually remedied the underlying issue of the pump being grounded?
A new M53 is ~$125 - $150 and the oil is not something you can walk into the hardware store and pick up off the shelf. I'd want to be certain you have fixed the ground first. Having worked on these in the past it is unlikely you are going to fix anything wrong with the winding, especially for less than a new unit.
If all is OK and the oil is all you need ask around at local pump repair shops for 10 or 20 weight non-detergent pump oil...they should know what you want and if they sell it, you should be all set. As for the amount, pour it in slowly until you see the winding is fully submerged. You need to leave room at the top to allow for thermal expansion of the oil.
John
Posted on Aug 29, 2011
Volvo penta aq151 how do drain engine oil
I haven't worked on boats for some time but in your case I remember we pumped the oil out through the dipstick tube. FYI you are in the wrong category, this is for cars. I would also contact a local boat dealer on this as well in case there is a simpler way to change the oil
Jun 02, 2016 | Volvo Cars & Trucks
How to change oil pump
Changing the oil pump is not easy, the oil pump is situated in the engine oil sump. So you have to go under the car and remove the oil sump pan to get at it. First you have to drain the oil. I recommend you buy a repair manual such as Haynes from a auto parts shop for about $15 before you start the job and follow the instructions in the manual. Good luck
Jun 25, 2014 | 1999 Dodge Durango
I need to remove the oil pomp on a 1.2 el fiat polio
drain engine sump and remove sump pan ,before changing pump check oil pump pick up not blocked
Jan 13, 2014 | Cars & Trucks
Oil Drain Plug location
The sump drain plug will be at the lowest possible point on the sump. The one in front of the water pump is probably the water drain plug.
Apr 10, 2013 | 1986 Honda VT 500 C Shadow
Kubota M 5030 2.8 6 cyl. Diesel in oil sump. Why?
Diesel gets in the sump from an seal leaking in the fuel pump through to the drive gear and out into the sump. If it has an inline pump( one where the injector lines are in a row at the top of the pump) the fuel will be leaking past the plunger elements and into the pump sump which then drains back tot he engine sump. IF it is slight but consistent sometimes injectors will dribble when shut down and the fuel will by pass the piston rings into the sump. Talk with a diesel pump and injector repair specialist for any faults particular to the Kubota fuel system
Apr 03, 2013 | Cars & Trucks
Oil drain pan on dodge durango
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html
Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 03, 2012 | 2008 Dodge Durango
Replace oil pump on a 1993 jetta celebration 3
The oil pump is located into a sump.Loose all the screws around the sump but the first drain the oil.You need also new sump gasket.
Apr 23, 2010 | 1993 Volkswagen Jetta
1998 VW Jetta with 2.0L 4cyl. No oil pressure or oil flow that I can see. Full on oil though, but absolutely dry in the valves. How difficult is it to replace the oil pump? Could something else be...
Did you have changed a cylinder head gasket? Possible turn around. If not need to change oil pump.It is easy.Just remove the sump but before that drain the oil because........Get new sump gasket.What about oil pressure lamp?Coming ON? If the engine runing and the lamp is ON change oil pump.
Apr 22, 2010 | 1998 Volkswagen Jetta
Where is the drain and filler plug on a 1984 honda125mthreewheel
Transmission and engine oil the same (... share a common sump ...)
Fill through the same place you put the engine oil in (also, check it)
Thanks for using FixYa.com
Positive comments appreciated
a
Oct 29, 2009 | 1997 Honda XLR 125 R
I need a picture of the diagram of the oil system
Here is a link to what you need and the guide below
http://i253.photobucket.com/albums/hh43/chuck943/A14937D.gif
Item Part Number Description 1 — Valve Tappet Vent Gallery (Open to Crankcase) (Part of 6049) 2 — Valve Tappet and Camshaft Bearing Feed Gallery (Reduced Pressure) (Part of 6049) 3 — Orifice and Strainer (Part of 6049) 4 — RH Head Gallery Oil Reservoir (Part of 6049) 5 — Primary Main Gallery Pressure (Not Restricted) (Part of 6010) 6 — LH Head Gallery Oil Reservoir (Part of 6049) 7 — Orifice and Strainer (Part of 6049) 8 6049 Cylinder Head 9 — Oil Drain to Sump (Part of 6049) 10 — To Hydraulic Timing Chain Tensioner (6L266) 11 — From Left Bank Cylinder Block (Part of 6010) 12 6714 Oil Bypass Filter 13 9278 Oil Pressure Sensor 14 6881 Oil Filter Adapter 15 — Oil Pump Integral Relief Valve (Part of 6010) 16 — Bypass (Part of 6010) 17 6600 Oil Pump 18 — To LH Cylinder Head (Part of 6049) 19 — Oil Drain to Sump (Part of 6010)
Mar 07, 2009 | 1995 Lincoln Town Car
Plumbing Logo
32 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
