Question about HP Photosmart M737 8 Megapixel Digital Camera
Camera lens wont close
I have been trying to close the camera lens for almost a year now. I have gotten frustrated with this that I want to get rid of it but. I cant so can you please help me.
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
I have a digital slr 400d canon camera. It is getting the message error 99 after taking a few pictures. what can I do to get rid of it?
Hi There,
on these models the 99 code is generic, and can mean a bunch of different errors, but usually it is dirty contacts. It can be on the battery, or more likely between the lens and camera body.
Check out this link here, there are a lot of good things to try.
http://www.fixya.com/support/t142115-canon_displaying_err_99
Good luck. And don't listen to the comments that Canon is bad, I have had Canon's for years, and they are great cameras!
Dec 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Unscrewing lenses
Hello toccata, It sounds like your lens mount is cross-threaded. Have you gotten a lens off and looked closely at your camera lens threads. Are they crunched together. You may need to get your cameras lens mount replaced and check all your lenses and see if the threads aren't cross threaded. If a lens has bad threads, don't use it anymore.
Jul 28, 2008 | Olympus EVOLT E-300 Digital Camera
Shutter having trouble opening and closing.
Hey SleepyFairy,
What it sounds like is that something sticky has gotten into the lens cover mechanism, and the only way to fix that is to have it repaired. If this camera is less that a year old it is most likely still covered under manufacturers warranty, and you should have it looked at by an authorized service technician to get it fixed.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Samsung NV10 lens won't retract/Autofocus doesn't work
please check your manufacture warranty as my samsung nv10 comes with a 2 year warranty
Feb 13, 2008 | Samsung NV10 Digital Camera
Casio Ex-z55 Lens cover not closing and lens does not operate
Buy the next camera- at 3 years old no economic repair will be feasible- but you could play with it some I guess
Aug 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens wont close.
Damage to the lens Mechanism is a repair shop job- or contact Kodak tech support for further advice.
May 13, 2007 | Kodak EasyShare CX7430 Digital Camera
Cannon Digital Rebel XT
"it no longer takes pictures" i'll need a bit more information from you but for now my first suggestion would be to (if the camera still powers up) try testing the shutter by finding the "sensor clean" option in your menu. (i don't have mine in front of me at the moment, but it's usually one of the last options) first remove the lens and select the sensor clean option. if the shutter opens, then the camera body itslef should be fine. the camera will instruct you how to close the shutter after. be extremely careful when the image sensor is exposed like this, make sure not to touch it and be sure to be in a clean area (dust on your sensor will frustrate you beyond belief) now i've had problem after problem with this standard 18-55mm lens. if the lens can't find a focal point, it won't fire. try switching to manual focus and see if it fires. if while focusing manually there is any resistence or grinding, chances are your lens is shot perhaps from being dropped or there is debris preventing auto focus mode to find a focal point. "i've had my camera for about a year" if you bought it new and have had it under a year, it should still be covered by warrenty and canon will take it back and make repairs (they gave me a new lens when this happened to me)
Apr 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
HP Photosmart M737 8 Megapixel Digital Camera Logo
13 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
