Question about Kodak Cameras
How to change battery on Kodak AF
What is procedure to change battery in Kodak AF 5x?
Can't find batteries for kodak avantix 3300AF camera
The 3300AF uses CR2 batteries, which should be available at just about any department, electronics, or office-supply store. One online source is here.
Feb 11, 2013 | Kodak Advantix 3300 AF APS Point and Shoot...
My kodak slice wont turn on anymore even after charging?Anybody?
Hello, The cold temps do have an effect on any type of battery, it is far cheaper to try a new battery that has been fully charged than to take the camera to a shop to be checked. All you will be out is the cost of the new battery.
Nov 30, 2012 | Kodak SLICE 14MP 5x Optical/5x Digital...
I'm trying to find a manual for a Kodak ektagraphic AF-3
You should still be able to get an AF-3 manual (e-copy) from the Kodak website, or contact the George Eastman House Museum. Good Luck!
Jim
Mar 19, 2012 | Kodak Office Equipment & Supplies
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
My Kodak easyshare c190 won't turn on, it just
Are you using alkaline batteries? I had the same problem -- my camera cut out after just a few pictures and when I tested the batteries they were practically full. But alkaline batteries, even 'super-heavy-duty' ones, aren't powerful enough for this job. You need better, preferable rechargeable batteries.
Mar 11, 2010 | Kodak Easyshare C190 12MP Digital Camera...
I have a camera kodak af. But for some reason does not working. I tried to use different battery to use but it is not working.
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
Nov 26, 2009 | Kodak 80-210mm f/4.5-5.6 Lens for Canon AF
Kodak AF power cycles, works in favorites mode
meybe the battery is to weak .
meybe the contet is broken
Jul 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
I have M1033 - when the shutter button is pressed half way down it wont focus and shows a red AF on screen. The pics are blurred. Batteries have been changed and lens cleaned.Help please
The red AF is autofocus. If it is red it isn't focused. You will have to hold the button until the red light turns green, then release the button.
Jul 08, 2009 | Kodak EasyShare M1033 - black Digital...
Cameras Logo
20 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
