Question about Video Game Consoles & Games
Bully requires a 32 bit display and vertex and pixel shader model 3.0 support
Help me
2 Suggested Answers
  • 111 Answers
SOURCE: when i try to play bully game on my PC i have
Im afraid this means your graphics card does not have pixel shader support- if you have a good processor speed download a pixel shader emulator otherwise you will need a new graphicscard that supports pixel shaders version 3
Posted on Apr 28, 2009
Bully game requires 32 bit display, and vertex and pixel shader model 3.0 support in my pc
your spech pc n your OS?
I use win 8 and i'll try with this answer first,
go to desktop, right click, click properties, and i think there is an option called display, click that, and change it to 32-bit colour
and ringht click on shortcut, run as administrator and play the game..
Feb 13, 2013 | Dell Inspiron 1501 Notebook
Spiderman friend or foe doesn't work
The most common problem shall be that your system might not meet the minimum requirements that the game needs...If you are sure that the requirements are met then you shall try to get another fresh copy of it as this may be corrupted.....If the minimum requirements are not met you can emulate the graphics that is needed for the game using 3D analyser....
May 10, 2011 | Activision Spider-Man: Friend or Foe for...
Where can i get 32 bit display, vertex pixel shader model 3.0 support
click the icon of your graphics setting(found at the bottom icons)then adjust settings or you can also do it in windows start;click start>then go to control panel>appearance and themes>display>then gp to settings...
hope it works and pls rate...tnx
Feb 12, 2011 | Dell Inspiron 1501 Notebook
Hi, when i start a new game in couple of games my display crashes, and shows paralell vertical lines and some brownish background... but the windows is still running in the background, but i can only turn...
Cardinal Rule 1
NEVER PLAY GAMES ON YOU MACHINE....
Cardinal Rule 2
If you insist to play games....go to a galeria and use the games video machine there.....
a few $ spent there will save your laptop....
Laptops are not ment for playing heavy games that require strong graphic card and heavy RAMs...
Dec 10, 2009 | Dell Inspiron 1501 Notebook
Can anyone please tell me if my video card is a capture card? Nvidia Geforce 6200 thanks joe
Tech Specs CineFX 3.0 Shading Architecture
  • Vertex Shaders
    • Support for Microsoft DirectX 9.0 Vertex Shader 3.0
    • Displacement mapping
    • Geometry instancing
    • Infinite length vertex programs
  • Pixel Shaders
    • Support for DirectX 9.0 Pixel Shader 3.0
    • Full pixel branching support
    • Support for Multiple Render Targets (MRTs)
    • Infinite length pixel programs
  • Next-Generation Texture Engine
    • Up to 16 textures per rendering pass
    • Support for 16-bit floating point format and 32-bit floating point format
    • Support for non-power of two textures
    • Support for sRGB texture format for gamma textures
    • DirectX and S3TC texture compression
    • Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes
64-Bit Texture Filtering and Blending
  • Full floating point support throughout entire pipeline
  • Floating point filtering improves the quality of images in motion
  • Floating point texturing drives new levels of clarity and image detail
  • Floating point frame buffer blending gives detail to special effects like motion blur and explosions
Intellisample 3.0 Technology
  • Advanced 16x anisotropic filtering
  • Blistering-fast antialiasing and compression performance
  • New rotated-grid antialiasing removes jagged edges for incredible edge quality
  • Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates
  • Fast z-clear
  • High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology
UltraShadow II Technology
  • Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3
TurboCache Technology
  • Shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for optimal system performance.
PureVideo Technology
  • Adaptable programmable video processor
  • MPEG video encode and decode
  • High-definition MPEG-2 hardware acceleration
  • High-quality video scaling and filtering
  • DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
  • Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
  • Display gamma correction
  • Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
Advanced Display Functionality
  • Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
  • Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
  • Full NVIDIA® nView™ multi-display technology capability
Advanced Engineering
  • Designed for PCI Express x16
  • Support for AGP 8X including Fast Writes and sideband addressing
  • Designed for high-speed GDDR3 memory
  • Advanced thermal management and thermal monitoring
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
  • DVC color controls
  • DVC image sharpening controls
Operating Systems
  • Windows XP
  • Windows ME
  • Windows 2000
  • Windows 9X
  • Macintosh OS, including OS X
  • Linux
API Support
  • Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0
  • Full OpenGL support, including OpenGL 2.0
GeForce 6 Series GPUs Features Comparison:
Feature GeForce 6800
Models
shim.gif GeForce 6600
Models
shim.gif GeForce 6200
Models
w/Turbocache
shim.gif Microsoft® DirectX® 9.0 SM 3.0 SM 3.0 SM 3.0 SM 3.0 Graphics Bus Technology AGP 8X/PCI Express AGP 8X/PCI Express AGP 8X/PCI Express PCI Express NVIDIA® Intellisample™ Technology 3.0 3.0 3.01 3.01 NVIDIA® SLI™ Technology X2 X2 n/a n/a NVIDIA® PureVideo™ Technology X3 X3 X3 X3 NVIDIA® TurboCache™ Technology n/a n/a n/a X4 64-bit Texture Filtering and Bending X X n/a n/a Effective Memory Interface 256-bit 128-bit 128-bit 128/64-bit Memory GDDR35 and DDR GDDR35 and DDR DDR DDR Process 0.13 micron 0.11 micron 0.11 micron 0.11 micron RAMDACs 400 MHz 400 MHz 400 MHz 400 MHz
1. GeForce 6200 models do not include compression technology.
2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only.
3. Features may vary by product. Some features may require additional software.
4. Available on select GeForce 6200 models only.
5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
Nov 20, 2009 | Nvidia GeForce 6200 AGP Graphic Card
When i try to play bully game on my PC i have error mesage '' Bully requires a 32 bit display, and vertex and pixel shader model 3.0 support what to do? thx russ
Apr 28, 2009 | Toshiba Satellite U300-ST3091 Notebook
Need a 64 mb video card supporting pixel & vertex shader 1.1
you can purchase those models easily on ebay, they are older video cards and should go very cheap.
Dec 19, 2008 | Dell Inspiron 1501 Notebook
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
