Question about Car Audio & Video
Reset clock on burlodge minigen
Trolley failed to come on after clock bst time change
Reset clock
Unplug and after a few minutes plug microwave to wall socket and follow the instructions above.
Dado
Mar 29, 2015 | Zanussi ZBM26542XA Stainless Steel...
Door will not open. Trolley moves towards door then forward an inch or so then stops.
Adjust your open and close positions on your door opener. Only adjust one at a time. Once you make an adjustment try to open and close. If it gets worse, go the other direction. If it does not change anything, then go to the other adjustment and repeat the process.
Nov 04, 2017 | Building Materials
Hi! I Have brand new Sharp Aquos LC-40LE824E. Everything is fine, except clock - it displays wrong time. The time is always 1 hour earlier than it should be. Is there a way to fix it? Thanks.
If you go into the main menu there maybe a BST setting that is OFF. Try and switch it on, then put correct time in.
Hope this helps.
Apr 12, 2011 | Televison & Video
Tried to pause live TV, on my Altech PVR6690, but it came up on the screen "abnormal timeshift" and won't let me pause.
I would check the clock time as we have errors if the clock is an hour out due to BST/GMT
Mar 29, 2011 | Televison & Video
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
After a power outage, my clock no longer has right time
You need to reset the microprocessor in the Clock/Radio. to do this you must unplug the Clock/ Radio and remove the battery. Let the Clock/Radio set for at least 1 hour to discharge the microprocessor. You can then reinsert the battery and plug in the Clock/Radio. The functions should return to normal. If you are still having a problem, try changing the battery (CR2430) and letting the Clock/Radio set unplugged for a longer period of time. If all this fails, you can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT and ask them for assistance. I hope this information help you with your problem.
Apr 01, 2009 | Emerson Smartset Clock Radio
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
