Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Vertical lines I've a Toshiba 46H84 Projection TV. When I first turn on TV, I've vertical lines across screen, but it does get better after it warms up. But now it seems to take longer to clear up, also I've noticed after it clears up, I've what they use to call ghost lines, but I use Directv satellite so that never has created a problem before, and I've two other TV's on the same dish without any problems. Before I noticed the vertical lines I did notice that the picture seemed dark and I adjusted the brightness on it, but it really did not make any kind of difference. Is this something I can repair myself by changing out a module?
  • 5 more comments
  • wagonmanc Nov 29, 2007
    I have the same problem
  • Anonymous Apr 13, 2008
    have same problem.
  • Anonymous May 22, 2008
    I have a similar issue but in addition to the vertical lines (bars) I also getting a herringbone pattern when the set is first turned on.
  • telepicker Nov 10, 2008
    When I first started having this same problem, my TV too would clear up after a time,however, now it is like this all the time and will not clear up and picture is horrible.
  • Anonymous Dec 24, 2008
    Same problem...s yours fixed?
  • Anonymous Feb 14, 2009
    can I repair this myself
  • don  Uffinger
    don Uffinger Mar 08, 2009
    I've a Toshiba 46H84 Projection TV. When I first turn on TV, I've vertical lines across screen, but it does get better after it warms up. But now it seems to take longer to clear up, also I've noticed after it clears up, I've what they use to call ghost lines, but I use Directv satellite so that never has created a problem before, and I've two other TV's on the same dish without any problems. Is this something I can repair myself by changing out a module or is it something that a repair man has to do?
    Genius:
  • 1,067 Answers
Hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
It has vertical lines
I had a similar problem and had to replace the computer chip.
Mar 01, 2014 | Toshiba 46H84 46" Rear Projection...
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
Black line running vertical from top to bottom toshibia tv 42
Model listed here is 46 inch---what is correct model of your TV?
Jun 15, 2012 | Toshiba 46H84 46" Rear Projection...
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
I have a Toshiba projection tv (46H84). When I
Yes!!!
You need to open the case, then remove the board from the unit, then check all the circuit, probably there's damaged circuit connections, use soldering iron to fix this problem....
Oct 18, 2009 | Televison & Video
I have vertical lines on my screen. They appear to
This a common problem in many of the Toshiba sets----set has a "HYPER" circuit board that processes all the signal for the set--surface mounted caps all start to dry out--always starts out where it will have the problem and then when on for a while it gets better and goes away--eventually when enough of the caps are gone--it never gets better.
Board is now only available by removing it and sending it out for rebuild/repair---company doining this is Pts electronics--part number is:
23148103Cost is about 180 dollars plus shipping and this may mean considering the labor to get the board out that the set is not worth repairing.
Sorry to give you bad news but I am certain this is what your trouble is.
I do this here for free so if this information helped you to decide what to do--take a minute and give me a vote here.
If you have questions or need advice reply to this posting here.
SD TECH
Sep 15, 2009 | Toshiba 46H84 46" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
983 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
